Getting some hubcentric rings machined...need width dimension...
Old Feb 6, 2006 | 10:29 AM
MR Dan's Avatar
Default Getting some hubcentric rings machined...need width dimension...
These are for my TE-37's...so far the specs of the rings are 73mmX64.15mm but what should the width be?? .375in ??? 1/2in??
Old Feb 6, 2006 | 02:27 PM
SpoolnEG6's Avatar
Default Re: Getting some hubcentric rings machined...need width dimension... (ITR908)
thats all you should need as far as info to go to a shop that sells them....
A common part # is usually an HR73-6415 or something along those lines. You shouldn't need to know any type of width
Old Feb 6, 2006 | 02:46 PM
mugenracer's Avatar
Most wheel shops should have a huge selection of rings available. When i was fitting my RGs i just went to my local place and started rooting through a big box of them till i got the correct size. They threw them in free with the new tyres i was getting fitted that day.
Old Feb 6, 2006 | 03:00 PM
JjuuN R's Avatar
well, you should definately not have to have custom ones made, sounds alot more expensive then digging through a box Discount Tire might have
Old Feb 6, 2006 | 06:32 PM
MR Dan's Avatar
Default Re: Getting some hubcentric rings machined...need width dimension... (JUN.R)
well...i'll be making them at work so its freeeeeee
Old Feb 6, 2006 | 06:40 PM
JjuuN R's Avatar
oh ok
Old Feb 7, 2006 | 08:15 AM
94rs-turbo's Avatar
does your steering wheel vibrate why so conserned with hub rigs?
blackeg
Feb 25, 2013 12:28 PM
Aarron_M
Feb 13, 2009 08:24 AM
poppypizza
Oct 17, 2008 11:33 AM
chairwitharmrests
Apr 10, 2008 10:28 AM
Todd00
May 29, 2003 08:47 PM
