wtb: 91 ls tranny
i need a 91 ls ( A1) 5 speed cable tranny, my zip code is 52001, if anyone has one please let me know how much you want for the tranny, and how much shipping will be.
thank you
thank you
From: gravity rides everything...everything will fall, se GA/ne FL
i have a '92-93 ls trans. great condition. better casing allowing you to utilize hydro b series trans parts later for upgrade. pm me if you are interested.
->kevin
->kevin
does that tranny have the same spline as the 91, cuz a while ago i had a 92 clucth and a 91 tranny and the 91 tranny spline was a little bit smaller than the 92?
90-91 is different.
i have two 90-91 ls trannys. the one needs new bearings and is all apart, ill let it go for 50 bucks + shipping. gears and case are still good just needs a rebuild.
the other i put new differential bearings in myself and I ended up messing something up and now it wont engage 5th gear, but I swear to god it did before I fucked with it. all the bearings are good, no input shaft play or output shaft play. ill let it go for 100 + shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3sgtecrazy »</TD></TR><TR><TD CLASS="quote">does that tranny have the same spline as the 91, cuz a while ago i had a 92 clucth and a 91 tranny and the 91 tranny spline was a little bit smaller than the 92?</TD></TR></TABLE>
my bad forgot about that issue.
im thinking i either put a syncro in the wrong spot or maybe a syncho sleve is upside down or something. when it was in my car 5th was totally blocked off, didnt even try to grind in or anything so something is blocking it.
yea im not really consered about it, all i really need the tranny for is about 6 months so if it will last me for 6 months i might be interested. all im gonna be doing for the next 6 months is working, im planning on getten a e36 m3
. so if that tranny will get me from home to work, from work to another job, and then from that other job back home, for 6 months i hav eno problem, let me see if i can find any other tranny in a week, after a week if i didint find another one, ill need that tranny off you.
yeah i cant guarantee how long its going to last, but i drove it in my car fora bout a month and put around 1,000 miles on it and it was ok for me just no 5th gear sucks on the highway.
