Rev limiter
Old Feb 6, 2006 | 06:47 AM
chicchocrider's Avatar
Default Rev limiter
Hey i bought my 2000 PY type r
The rev limiter on it is set to 9600rpm!!! on stock everything!
Just want to know how to bring it back to stock condition before I blow everything up
There is also the vtec engagement point which is set at 5800 rpm
I also whant to set it back to stock
Thanks!
Old Feb 6, 2006 | 07:13 AM
RagingAngel's Avatar
Default Re: Rev limiter (chicchocrider)
Welcome to the elitist club.....
First of all don't shift at 9600rpm. Even if it is indicated on the tach as being that high, it's likely to be lower since the stock tachometer is notoriously inaccurate at higher revs.
Shift at indicated redline instead - instead of bouncing off the rev limiter.
The 5800rpm VTEC Xover sounds normal.
If you want everything to be stock...you can try searching for a stock ECU.
Enjoy your stay.
Old Feb 6, 2006 | 07:58 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chicchocrider &raquo;</TD></TR><TR><TD CLASS="quote">Hey i bought my 2000 PY type r
Thanks!</TD></TR></TABLE>
What are you using to change the VTEC and rev limit? Hondata, Uberdata, ?
Congrats on the purchace. If I just bought a car, and found that the rev limit was already changed to 9600 RPM, I'd be a little pissed
Old Feb 6, 2006 | 08:44 AM
B7AudiA4's Avatar
Default Re: Rev limiter (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Congrats on the purchace. If I just bought a car, and found that the rev limit was already changed to 9600 RPM, I'd be a little pissed </TD></TR></TABLE>
same... But 5800 on vtec engage is right...
Old Feb 6, 2006 | 11:19 AM
Circuit Star-29's Avatar
Default Re: Rev limiter (FutureITR)
Whats a "REV-limiter"?
Singlecam4dr
Jan 27, 2007 11:50 AM
mozzandherb
Jun 19, 2006 08:20 AM
M2nR
57
Sep 22, 2005 05:56 PM
92ehatch
Jul 25, 2005 11:04 AM
Toda Party
Jul 30, 2001 05:10 PM
