Wiring Diagram of USDM Fog Switch?
Old Mar 25, 2002 | 02:02 PM
98R-1144's Avatar
Default Wiring Diagram of USDM Fog Switch?
anybody happen to have a picture or description of what each prong is on the back of a USDM fog light switch?
Old Mar 25, 2002 | 02:47 PM
Nighthawk GS-R's Avatar
New User
Default Re: Wiring Diagram of USDM Fog Switch? (98R-1144)
yeah im interested as well, if anyone can help us out.........
Old Mar 25, 2002 | 03:45 PM
Dropspeed's Avatar
What are your trying to do? I have 2 in my car, one wired into aftermarket foglamps and one to raise or lower the antenna. If you are just looking for the 2 pins that you need to run power to, I can pop one out and check, I can't remember off the top of my head.
Matt
Old Mar 25, 2002 | 03:47 PM
98R-1144's Avatar
Default Re: Wiring Diagram of USDM Fog Switch? (Dropspeed)
i need it to hook up to my JDM ITR fog lights. right now i have a generic kragen's rocker switch... i just like the OEM look better. i just need to know which 2 prongs to attach the power and ground to.
thanks!
Old Mar 25, 2002 | 03:59 PM
Dropspeed's Avatar
O.k I just ran out there. If you hold the switch with the green illumination light at the top and turn it around you will see 4 pins going down on the left side and one on the right side. The single pin on the right side is to the lights. The 3rd pin down on the left is a ground and the 4 pin down on the left is a power wire. Hopefully this works
I I FOGS
I
I GND
I PWR
That is supposed to look like the back of the switch.
Mattj
PS thats at least how mine are wired. BTW it about 25 outside and snowing
[Modified by Dropspeed, 8:01 PM 3/25/2002]
Old Mar 25, 2002 | 06:56 PM
98R-1144's Avatar
thanks for the info! what exactly is the pin to the LIGHTS for?? the way my current rocker switch works is just a power and ground attached to it (the power goes to my relay which goes to the lights).
you think the switch would still work if i just have the power + ground hooked up?
Old Mar 25, 2002 | 07:02 PM
Dropspeed's Avatar
On "most" Driving/Fog lamps the switch has power coming into the switch and then when the button is depressed it is connected and flow out of the switch to the lights. I don't know your set up, but try to use the one one for power and the one to the lights and that should work.
Mattj
jdmjohn1
Jul 3, 2012 09:48 PM
honda95civic
Audio / Security / Video
Jul 20, 2006 08:16 PM
sdcrx9d1
Jun 19, 2005 09:47 PM
GQ Cowboy
Dec 11, 2003 01:23 PM
