Help with frozen Emergency Brake
Old Feb 6, 2006 | 04:49 AM
b18cEK's Avatar
Default Help with frozen Emergency Brake
I parked my car outside for the first time the other night and the e-brake is frozen ( I believe) on the passenger side only.
I beat the **** out of it with a mallet, but no luck!
What else can I do to free it up?
Old Feb 6, 2006 | 04:56 AM
MikeD718's Avatar
Default Re: Help with frozen Emergency Brake (civic-rmod)
park it in a garage for a few hours with the brake off, it will thaw out. you shouldnt use your e-brake in freezing weather unless it is absolutly necessary.
Old Feb 6, 2006 | 04:57 AM
b18cEK's Avatar
Default Re: Help with frozen Emergency Brake (MikeD718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeD718 &raquo;</TD></TR><TR><TD CLASS="quote">park it in a garage for a few hours with the brake off, it will thaw out. you shouldnt use your e-brake in freezing weather unless it is absolutly necessary. </TD></TR></TABLE>
It's been in my garage overnight and it's still stuck! (garage isn't heated)
It's only like 10 degrees out!
Old Feb 6, 2006 | 05:39 AM
hondapwr's Avatar
Did you try penetrating grease yet?
Do you have electric in your garage? If so, aim a space heater at it (and monitor carefully)
Old Feb 6, 2006 | 05:55 AM
b18cEK's Avatar
Default Re: Help with frozen Emergency Brake (hondapwr)
no, I didn't apply penetrating grease.
Where do I spray it?
Old Feb 6, 2006 | 07:03 AM
Frozen E's Avatar
H-T White Ops
drive it out onto a non-icy area. They'll break free.
Old Feb 6, 2006 | 07:08 AM
b18cEK's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">drive it out onto a non-icy area. They'll break free.</TD></TR></TABLE>
I have, I put about 30 or so miles on. They seem to break free after awhile of driving, but once I park it, they freeze up again.
and I am not using the e-brake either.....
Old Feb 6, 2006 | 07:13 AM
Frozen E's Avatar
H-T White Ops
run a hair dryer all along the brake cable
Old Feb 6, 2006 | 10:03 AM
b18cEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">run a hair dryer all along the brake cable</TD></TR></TABLE>
just did, but no luck!
that bitch is really stuck on there. I could get the lug nuts off with the car jacked up and the wheel didnt budge at all...
Old Dec 22, 2008 | 06:46 AM
cor-e's Avatar
I know this thread is old, but is there anything else that can be done to brake the wheel loose?
I had this happen to me last night and it really sucked. It's happened a few times before, but not as bad as last night (it was 8 degrees).
Should I worry about just putting the car in gear to park it. Is one gear better than another?
Old Dec 22, 2008 | 07:47 AM
zeplin's Avatar
Any gear will hold just fine. I always throw mine in first during cold weather. Just remember to hold the brake or put it in neutral before you start it up!
charlee
Feb 4, 2007 09:09 PM
siblues
Audio / Security / Video
Sep 8, 2006 04:01 PM
CPR
Jan 29, 2006 07:48 PM
chansw
May 30, 2004 05:24 PM
udm_motorsport
Mar 10, 2004 06:17 AM
