skunk2 intake manifold on gsr, which TB?
Old Mar 25, 2002 | 01:12 PM
spankaveli's Avatar
Default skunk2 intake manifold on gsr, which TB?
what throttle body are you guys using on your skunk2 intake manifolds? i know the stock gsr is 60mm, and the skunk2 manifold is 64... should i just try to find a bored type R ? or get a jg/edelbrock 65mm?
what are you guys running? suggestions please
Old Mar 25, 2002 | 01:46 PM
Spyderwebab's Avatar
Default Re: skunk2 intake manifold on gsr, which TB? (spankaveli)
Skunk2 recommends the Type R TB...but I just don't have the $500 to cough up for it. So my stock TB is working just fine
Old Mar 25, 2002 | 02:06 PM
GSR_Hacker's Avatar
New User
Honestly... I had the Skunk2 IM and what worked best was the stock GSR sent to Raver Motorsports for a 64mm bore...
Vernon did an awsome job and had great turnaround time... woth the money
Contact:
Raver Motorsports
Vernon
(559) 733 4711
Old Mar 25, 2002 | 05:28 PM
spankaveli's Avatar
ttt, this place moves quick
Old Mar 25, 2002 | 05:40 PM
stick's Avatar
saw ur web page. pretty nice set up.
but i use stock GSR TB for mine.
i would recommend the following if u plan on keeping it all motor.
u will need ITR CAI but think about:
higher compression
better flowing header
ITR camshafts or better
VAFC
adj FPR
cam gears
lots of tuning and dyno time and ur teg will scream
Old Mar 25, 2002 | 05:44 PM
spankaveli's Avatar
Default Re: skunk2 intake manifold on gsr, which TB? (stick)
well i have a custom ice-box type setup on the car, it should work fine. my plans are:
itr pistons, 2 layer head gasket, (maybe LS block), skunk2 stage 2 cams, skunk2 valvetrain, skunk2 ecu, skunk2 cam gears, jdm dc header, carsound cat, 2.5" piping, b&m fpr and fpg, vafc & lots of tuning. oh and a 65 shot direct port
btw, its in a civic, not a teg
[Modified by spankaveli, 8:45 PM 3/25/2002]
lambdasquared
Jul 24, 2014 07:05 PM
katanamast279
Apr 16, 2009 07:22 AM
JDMvtecDRAGSTA
Mar 29, 2004 09:00 AM
ITRfaithful
May 14, 2002 01:35 PM
