Need help! Engine is a 95! >=|
Old Feb 5, 2006 | 08:34 PM
wwang924's Avatar
Default Need help! Engine is a 95! >=|
Okay, i have a couple questions. Basically i was doing a swap and i THOUGHT i had a 96 LS, now im pretty sure its a 95. I have a 96 EK, i've been working on it and is almost done until i realized then 96 harness plugs didn't match up with the injectors on the LS engine. Will the injectors from the Ek work in the LS motor, also it seems that i only have 4 plugs left to plug and there are 5 on the engine.
To clarify there are three 2-wire plugs and two 3-wire plugs and i only have 4 plugs on the harness left, because everything else i have already plugged in.
So i just need to know if the injectors will work, and what to do about the plugs. The remaining plugs are are all on the intake manifold. THanks guys.
*edit* also, i bought a OBDII Dizzy, OBDII ECU.
Old Feb 5, 2006 | 11:31 PM
wwang924's Avatar
Default Re: Need help! Engine is a 95! >=| (wwang924)
bump
Old Feb 6, 2006 | 04:09 PM
wwang924's Avatar
bump
Old Feb 6, 2006 | 05:29 PM
wwang924's Avatar
maybe i can rephrase my question, if somone can offer me a pic maybe of the intake manifold and label the sensors for me that would be great, thanks. And i have searched, but recently a lot of threads w/ pictures dont work. Thanks guys.
Old Feb 6, 2006 | 10:34 PM
wwang924's Avatar
last bump....
Old Feb 7, 2006 | 12:42 AM
sicky's Avatar
grammer nawzi
why don't you just check the stamp on the motor. will be on the head on the front right-hand side. It will tell you the year the motor was made.
Old Feb 7, 2006 | 11:21 AM
wwang924's Avatar
Default Re: Need help! Engine is a 95! >=| (sicky)
the stamp you are talking about is it near where it says B18B1?
mrinno
Nov 28, 2006 11:00 AM
moshi moshi
Nov 21, 2005 06:25 PM
perfecttiming
Oct 22, 2004 06:17 AM
Nameless RB26
Sep 5, 2002 09:54 PM
