zc obd1
Old Feb 5, 2006 | 06:28 PM
deerek101's Avatar
Default zc obd1
is it easy to swap a obd1 into my dohc zc motor i thought they came with that ecu but mine hase a b18a1 ecu and is seems like its running too rich im trying to figure this out because it bogs in the low rpms and my new plugs are black already i have a aem fuel presssure regulator and rail and a msd but its still to rich should i obtain a obd1 or what
Old Feb 5, 2006 | 06:39 PM
90SICRX's Avatar
Are you saying that the motor is OBD1 or you want to go OBD1? I would assume you have a DOHC ZC from a 88-91 crx si. If so then the ecu you currently have is wrong. You want a PM7 or PG7 ecu.
Old Feb 5, 2006 | 06:59 PM
deerek101's Avatar
Default Re: (90SICRX)
well i have a dohc zc motor but my ecu is a b18a1 non vtec one i dont know how it got there i bought it like that i thought the zc was obd1 maby im mistaken
Old Feb 5, 2006 | 07:21 PM
90SICRX's Avatar
Default Re: (deerek101)
It dependes on what year the motor is
Old Feb 5, 2006 | 09:38 PM
EF9ZC's Avatar
get a 89 integra ecu at a local junk yard
Old Feb 5, 2006 | 09:44 PM
Mach69's Avatar
Default Re: zc obd1 (deerek101)
Some ZCs came obd-1, but that doesn't really matter.
You will want to completely forget the obd-1 stuff. Just run a pm7 or a pg7. Or you could get a 90-91 pm6 ecu and chip it with pm7 fuel maps (with TURBOEDIT and no other program).
onesixteen
10
Mar 2, 2008 09:40 AM
baboracus
Aug 11, 2006 12:39 PM
ZC CivicJdm
Jun 15, 2006 12:14 PM
. M i c h a e l
Mar 25, 2006 02:59 PM
99sonicbluegsr
Mar 28, 2005 05:01 PM
