Strange Oil Leak
Old Feb 5, 2006 | 06:24 PM
GaRn's Avatar
Default Strange Oil Leak
I have a weird oil leak on my hands here.. I replaced the crank main, the balance shaft seal/retainer, and the cam seals a while back, and has been dripping oil slowly for a while now..
I took off the cover today, and the leak is not coming from either the crank main or the balance shaft seal that I replaced its not from up top near the cam seals either.. I found oil on the balance shaft belt tensioner(balance shaft belt is off) and behind the tensioner where it bolts to the block. I took off the balance shaft gearset and I don't think it is coming from there either.. I might replace the o-ring seal, but anyone have any ideas?
The bolt that the tensioner is on doesn't go into the crankcase does it?
Old Feb 5, 2006 | 08:32 PM
CGags13's Avatar
Default Re: Strange Oil Leak (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">I have a weird oil leak on my hands here.. I replaced the crank main, the balance shaft seal/retainer, and the cam seals a while back, and has been dripping oil slowly for a while now..
The bolt that the tensioner is on doesn't go into the crankcase does it?</TD></TR></TABLE>
no, it doesnt. however if theres oil around your tensioner, it may be that the tensioner itself is leaking oil..(Hurry up and replace before bent valves )
if not, then your only other option is the gearset cover...ive seen them leak slowly alot...esp if you have ever taken it off and reused the o-ring on it...but now that youve taken it off make sure you get a new o-ring for that gearcase...
those are the only 2 options left...are you 100% positive that its coming from this area of the engine???
Old Feb 6, 2006 | 06:42 AM
GaRn's Avatar
Default Re: Strange Oil Leak (CGags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 &raquo;</TD></TR><TR><TD CLASS="quote">no, it doesnt. however if theres oil around your tensioner, it may be that the tensioner itself is leaking oil..(Hurry up and replace before bent valves )
those are the only 2 options left...are you 100% positive that its coming from this area of the engine???</TD></TR></TABLE>
Yea, the oil is dripping out of the vent hole in the bottom of the plastic cover...
The tensioner bearings seem to be sealed type, but is it possible that they filled with oil when my balance shaft seal popped out spewing oil everywhere, and it is just leaking oil now that it is spinning?
Old Feb 6, 2006 | 08:33 AM
CGags13's Avatar
its possible that some old oil from the seal popping is finding its way out now that the engine is running....
however, it shouldnt be alot unless you didnt clean up this previous mess well...
Allout
Feb 16, 2010 03:56 PM
F22dreams
Dec 12, 2007 03:59 AM
ty_racer
Apr 1, 2005 01:49 PM
Boostless97Lude
Jan 8, 2003 11:01 AM
Chiovnidca
Jan 3, 2003 10:28 AM
