obd0--->obd1 question
I don't know if the picture will work, but my question is on all the obd0 to obd1 harnesses i see for sale there is always that pigtail that goes along with the conversion harness. what is the pigtail for???
for a 4 wire o2 sensor, vtec selnoid,vtec pressure sending unit, knock sensor, 2 are for a switch to check engine codes, one is for something on the butterflies that kick in on a gs-r...the harness will come with directions that will tell you....it is not hard to figure out.
you will connect those to the 4 wire O2, knock sensor, VTEC solenoid, VTEC pressure switch, VTEC pressure switch ground, CEL, IAB wiring on GSR's. If you need the sensor plugs and wiring to connect to these shoot me a PM I have them ready to go
Hondamonster
Jun 6, 2007 08:04 PM
