00 si (B16a2) Idle at 1500 and 1200 RPM, HELP.
Yestday I got my Master Cylinder, Brake Booster, Honda Tramssion oil, and Mobile 1 engine oil replaced at once.
Good news is braking issue is fixed. Bad news is this...
I felt the car is a little different in the way it sounds and performs.
Im not sure if this is normal after a tramssion oil change. I thought maybe it needs to settled in. That thought could be stupid. I dont know what the mechanic did cause i wasn't there when he did all of this. When driving normal, the car now idles at 1500 then slightly drops to 1200 and goes back up to 1500. It only flucuates a little but mostly stay at 1500. I dont like the feeling at all. Need your guys help on this one before heading back to the shop this week.
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si »</TD></TR><TR><TD CLASS="quote">Inspect the vacuum lines around the brake booster. Sounds like a vacuum leak, not an engine oil/trans fluid issue.
Adi</TD></TR></TABLE>
I will check that. thanks.
I also wanna note that if I tap on the gas pedal a little bit, the car kinda sputtered. This is when it idles at 1500. Hope this help too.
Adi</TD></TR></TABLE> it does sound like a vacuum leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirtfall »</TD></TR><TR><TD CLASS="quote">spray some carb cleaner around the area you think might have a leak and if you hear the motor rev a little then youve found the leak</TD></TR></TABLE>
I will give that a try tomorrow as well. I just hope its not the brake booster and master cylinder cuase they were perchased used at the junkyard for a reasonable price with a 30 day warranty.
