HF gauge cluster in STD
Old Feb 5, 2006 | 05:22 PM
autoxef's Avatar
Default HF gauge cluster in STD
I have a 90 standard hatch and got a instrument panel with tach from a 90 CRX HF. I swapped over my speedo/odometer and everything plugged in fine but the tach does not work correctly. It does not register at idle and will only start climbing at abouy 4000 rpm. Did i get a bad one or is it something else?
thanks
Old Feb 5, 2006 | 05:52 PM
beyondspexj's Avatar
you might have messed something up when you swapped your speedo in. or maybe you got a bad one. try getting another one and plug it in first and make sure it works. then swap your speedo over
CRXcracker
Jun 11, 2004 12:35 PM
ltho1998
Jul 20, 2003 06:24 PM
thegrinch
Jun 9, 2003 11:43 PM
Timmah!!
12
May 9, 2003 01:23 AM
justagsr
Jul 16, 2002 08:34 AM
