dyno my new ITR motor!
Old Feb 5, 2006 | 04:51 PM
intech's Avatar
Default dyno my new ITR motor!
i dyno'd my car today it ran at 170 hp at the wheels at 9000rpm and 140 lb torqe. i want more power but have limited funds. i found hondata s200 on ebay for $300 is it worth it. or should i get fuel rail, injectors and pressure regulator. or skunk2 throttle body and intake manifold. which one of those three would give me the best gain for the money. someone give me some ideas on what i should get to gain some affordable hp. i already have cold air intake, header, exhaust.
Old Feb 8, 2006 | 02:50 AM
benjamin's Avatar
Default Re: dyno my new ITR motor! (intech)
after intake header and exhaust i would look into head work or turbo. hondata s200 is not worth it. If you want to tune your car buy a p28 ecu a plx 300 air/fuel ratio reader and a wide band o2 sensor. Then down load crome which is a rom editor that is less user friendly than hondata s200 but is about 200 dollars cheaper and you can tune ur car yourself for a specific air fuel ratio.
Old Feb 8, 2006 | 03:01 AM
Reid's Avatar
Global Moderator
If you're not using a header with a 2.5" collector, get one of those first.
DiRT3DiM3
32
Feb 22, 2012 08:59 PM
BoostedJeff
Honda Civic (2006 - 2015)
35
Mar 29, 2010 06:33 AM
98or00gsr
May 2, 2007 03:02 PM
michaelduvall
Apr 21, 2004 07:31 PM
SashK
Oct 10, 2003 05:33 AM
