would u boost a 230k miles ls motor ?
Old Feb 5, 2006 | 04:02 PM
EK FLY's Avatar
Default would u boost a 230k miles ls motor ?
resently i bough a beater a 1990 integra ls for 800 $ it has 230k miles the motor still runing strongh no problems no smoke I havent done a compr test but i will soon my question is would u boost that motor to like around 5 to 8 psi ?
Old Feb 5, 2006 | 04:05 PM
Dunc's Avatar
BCICAN
Default Re: would u boost a 230k miles ls motor ? (EGSR)
Here is what people will tell you:
1.) Do a compression test
2.) Do a leak down test
3.) If 1 & 2 turn out good, boost it.
Old Feb 5, 2006 | 04:11 PM
Boner_Ben's Avatar
Boost it. If shes too worn and blows then rebuild after that!
Old Feb 5, 2006 | 04:17 PM
EK FLY's Avatar
Default Re: (Boner_Ben)
do u really think it would happen something at 8 lb ?
Old Feb 5, 2006 | 04:27 PM
Boner_Ben's Avatar
Anything can happen what are you going to tune the car with? 230k is alot of miles, but if the compression is alright then its irrelevent.
Old Feb 5, 2006 | 06:38 PM
urbansi's Avatar
Think of it this way, if you knew a girl that had un-protected sex with over 300 men, and after those thoughts you still wanted to have sex with her, wouldnt you think about doing some tests before you just see what happens . JMO
Old Feb 6, 2006 | 05:36 AM
zeroice's Avatar
Default Re: (urbansi)
good example
Old Feb 6, 2006 | 05:51 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">Think of it this way, if you knew a girl that had un-protected sex with over 300 men, and after those thoughts you still wanted to have sex with her, wouldnt you think about doing some tests before you just see what happens . JMO</TD></TR></TABLE>
yeh same exact situation lol
but seriously, just boost it, whats the worst that can happen....it'll lose compression faster and you'll need to buy a new motor, right?
well if the motor isn't good now, you'll either need to rebuild it first or buy another. So basically you can't lose, just do it!!
Old Feb 6, 2006 | 06:05 AM
hondaguyef's Avatar
Default Re: would u boost a 230k miles ls motor ? (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
3.) If 1 & 2 turn out good, boost it.</TD></TR></TABLE>
Regardless of mileage ^^^. I've boosted a few LS's w/ over 100K and one w/ over 200k. No issues except traction problems
Phil
Old Feb 6, 2006 | 06:16 AM
King Tut33's Avatar
Just do it. I just boosted my LS with 218,000 miles and she is running perfectly on Uberdata at 7 psi.
Old Feb 6, 2006 | 06:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Here is what people will tell you:
in a nutshell.
Old Feb 6, 2006 | 09:07 AM
99lspwr's Avatar
Default Re: would u boost a 230k miles ls motor ? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
Haha, I second that!!! Especailly with b.s. engine management, and still never had any problems...
Old Feb 6, 2006 | 12:28 PM
nerdsports's Avatar
time to convince my g/f to boost her LS.
Old Feb 7, 2006 | 06:38 AM
Mr. Badwrench
Default Re: would u boost a 230k miles ls motor ? (99lspwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Haha, I second that!!! Especailly with b.s. engine management, and still never had any problems... </TD></TR></TABLE>
it aint b.s. if it is working for you frank.
BUT i wont call it a fluke is you do it on another car and make it work. j/k. he hee.
Old Feb 8, 2006 | 10:28 AM
99lspwr's Avatar
Default Re: would u boost a 230k miles ls motor ? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
BUT i wont call it a fluke is you do it on another car and make it work. j/k. he hee.</TD></TR></TABLE>
**** man, all I ever do is boost the **** out of old *** stock motors!!!Must be a long string of flukes for me huh?? haha
Old Feb 8, 2006 | 10:52 AM
Mr. Badwrench
if i try that stuff, i usually weld pistons to wrist pins.
Old Feb 8, 2006 | 11:58 AM
beerbongskickass's Avatar
I'd watch out for the rods letting go with that many miles on the motor.
Old Feb 8, 2006 | 12:11 PM
redzcstandardhatch's Avatar
something different
it'll be fine well tuned, lower psi.
its been done...
any engine can let go any time though, once its pushed a bunch. sometimes there are weak links to an engine. not too common with honda's though...they are TOUGH for what they are.
a buddy of mine made 230 whp on a 200K d16z6 block.
Old Feb 8, 2006 | 12:15 PM
Default Re: (redzcstandardhatch)
The LS rods are different than the b16/gsr rods. The design of the big end puts all the pressure on the rod bolts.
Old Feb 8, 2006 | 06:03 PM
blackeg's Avatar
id boost it. tune it well, 5-7 psi, your fine. i boosted mine at about 205k, and it was still running perfectly at 215k when i took it out
Christopherian1982
Jun 14, 2008 10:57 PM
1.8
Jan 30, 2005 03:07 PM
H.A.R.T B18C1EG6
Oct 4, 2004 10:18 AM
MarkAngelo
Sep 16, 2004 10:39 PM
DeL SLo
Jan 11, 2003 11:43 AM
