does cometic make a turbo headgasket?
What exactly is your definition of a "turbo" head gasket. They have a full line of multi layer steel sandwich gaskets that work great on turbo applications. Many thickness and bore sizes available for all B series engines.
i guess i ment to say something that will be stronger. how about this one on page 27 for a b18b?
http://www.cometic.com/catalogs/AutoCat04.pdf
i prefer to use oem gasket or golden eagle, b/c i used cometic and blew that hg in like 2500 miles. its either a hit or miss on those head gaskets
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 »</TD></TR><TR><TD CLASS="quote">i prefer to use oem gasket or golden eagle, b/c i used cometic and blew that hg in like 2500 miles. its either a hit or miss on those head gaskets</TD></TR></TABLE>
Not really. 99% of the time its installer error.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">
Not really. 99% of the time its installer error.</TD></TR></TABLE>or the parts that are being sealed together
Block/Head flatness, surface finish, etc. I think Cometic specifies 50RA or finer finish for their MLS gaskets.
Improperly torquing the head doesn't help either.
Cometic has the HP gaskets. Known as High Pressure. They are still an MLS gasket but they have a thicker ring that surrounds the bores in order to provide additional sealing for boosted/n2o applications. We usually try to stock them in various sizes and thickness's, if you cant find one then its usually a 2-3 week wait from Cometic for them to make one.
how the hell would it be installer error? i built a spare motor on the side to build and did everything correctly. i torque them down correctly step by step in order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 »</TD></TR><TR><TD CLASS="quote">how the hell would it be installer error? i built a spare motor on the side to build and did everything correctly. i torque them down correctly step by step in order.</TD></TR></TABLE>
How could I verify that? ( no offense ) .
Did you check for surface irregularites?
was the surfaced straight? damn dude you act like i am dumb. i had the block resurfaced when i got it sleeved and had my head resurface when i had my port job done.
