92 ls swap into 88 ef hatch dx? cranks but no start!!!
Old Feb 5, 2006 | 10:06 AM
CR-V-tech's Avatar
Default 92 ls swap into 88 ef hatch dx? cranks but no start!!!
ok guys here's the scoop I have the swap done I have re-pinned all the wires to there specific locations as per the guys at boomslang! thank you lord for those guys! I have spark and the injectors are firing, the pump still won't come on and I have powered it up but still won't start. I have got it to run on some starter fluid and can keep it running that way but still won't start and run on it's own! the car is throwing a code 6 and 16 ! 6 is ect which i know what is wrong there, the wire is broke! but as for the injectors I have no clue? there isn't a resistor box on the car at all. there's no provisions on the hasport harness! not even a single plug for one! the engine is 92 ls obd1, the ecu is the same, but I was looking at the integra and there is a resistor box in it even though it is obd1! but there isn't one on the hatch!
oh and it's not the main relay either I've checked it in another car and all was good! so i am still at a loss if anyone can help i would greatly appreciate it , thanks josh
Old Feb 5, 2006 | 10:54 AM
jlicrx's Avatar
Default Re: 92 ls swap into 88 ef hatch dx? cranks but no start!!! (CR-V-tech)
does it have OBD1 injectors?
Old Feb 5, 2006 | 11:03 AM
CR-V-tech's Avatar
Default Re: 92 ls swap into 88 ef hatch dx? cranks but no start!!! (jlicrx)
yes it does the swap and ecu are out of a 92 obd1 integra
crxb16a90
Dec 23, 2009 03:11 PM
dump3deg6
35
Feb 17, 2009 07:48 PM
