camber kit
Old Feb 5, 2006 | 09:32 AM
00accordguy's Avatar
Default camber kit
should i get a camber kit and put it on before i do my drop, im only going down abt an ince or so, with coilovers, im not too worried about tire wear over a few weeks, but i just was wondering if it would be easier to do while i have it broken down or should i just bring it to a shop and get them to put it on?
any help would be appriciated asap cuz i want to put in on in the next day or two
austin
Old Feb 5, 2006 | 11:04 AM
hondadude's Avatar
Default Re: camber kit (00accordguy)
I always advise the camber kit for any drop; It gives you more options for alignment.
Old Feb 5, 2006 | 11:09 AM
Default Re: camber kit (hondadude)
ok thanks, but what about installing issues?
Old Feb 5, 2006 | 11:12 AM
P_Adams's Avatar
I (as does HondaDude) always recommend a "Camber Kit" when performing a drop. The answer to your question you posed can be answered this way.
If you elect to use Adjustable ball joints as a Camber Adjustment method, you can pick them up before hand.
If you elect to use the offset bushing method, you'll have to wait until after the drop is performed to determine which offset value you need. The Offset bushings adjust within certain ranges and unlike the adjustable Ball Joints are NOT infinitely adjustable.
P
Old Feb 5, 2006 | 02:33 PM
Default Re: camber kit (P_Adams)
how much would adjustable ball joints be for front and back?
Old Feb 6, 2006 | 01:48 AM
AccordRacing's Avatar
Installing a camber kit while you have the suspension apart, beleive it or not, will be a harder install. To install a camber kit you leave the tire on, remove the two nuts securing the achnor bolts to the frame, jack up the vehicle, hit the achnor bolts lightly w. a rubber mallet to drop them down, then swing the arm around and rest it on the tire as you remove the control arm to anchor bolts. I highly recommend using a torque wrench to re install the bolts to proper torque .. also make sure you put the bolt in the same way it came out b/c in case it comes loose it will keep the control arm intacted b/c the bolt will hit the frame instead of sliding all the way out (i found this out the hard way).
19Accord97
Mar 25, 2009 06:25 PM
FLACO EM1
Nov 27, 2008 01:39 PM
vtec_head
10
Aug 9, 2006 03:27 AM
skrewdlude
Feb 18, 2003 06:53 AM
631 Teggy
Jan 18, 2003 07:38 AM
