Traction Bar Install - Oem Removal - How HARD Is It?
Old Feb 4, 2006 | 08:38 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Traction Bar Install - Oem Removal - How HARD Is It?
I want to install this traction bar setup (it says this is for a crx and he says there only 2 bolts on each side, is that right?)
How hard is it to remove the stock crossmembers on these old *** cars with hand tools and a descent 1/2" impact gun
Im thinking of getting a set of bars, but only if I wont have problems installing
Old Feb 4, 2006 | 08:48 PM
theinfamouskonrad's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (Oceanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oceanic &raquo;</TD></TR><TR><TD CLASS="quote">
Im thinking of getting a set of bars, but only if I wont have problems installing</TD></TR></TABLE>
Yea 2 bolts on each side. Shouldnt be that hard to get the stock one off. Spray the bolts with some pb blaster first. The tricky part is loosening/tightening the bolts that connect to your control arm since your strut is right there. You can just remove it and install should be a breeze.
Old Feb 4, 2006 | 10:28 PM
Chase's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (konrad)
I didnt even use any power/air tools. Just some wd-40 and hand tools.
Old Feb 5, 2006 | 01:11 AM
beyondspexj's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">I didnt even use any power/air tools. Just some wd-40 and hand tools. </TD></TR></TABLE>
yup the first time i did mine i used some man muscle. lol. well i had no choice.
Old Feb 5, 2006 | 01:31 AM
crxnj's Avatar
Heres a tip,,put a jack under the crossmember to support it when you're taking the bolts off,,and use a long bar for leverage to get the bolts off..
Its really easy ,,Take the bolts off of the lca that hold on the radius arms then remove the bolts that hold the crossmember to the frame..
Old Feb 5, 2006 | 09:31 AM
PINKS's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (Mr.speaker)
Anyone have a pic of how it cnnects to our car? its snowing here and I cant get to mine,I always though it was a sideways triagnel shape with 3 bolts on each side connecting them
So there isnt a huge problem removing them like out lca bolts? Fairly easy
Old Feb 5, 2006 | 11:05 AM
PINKS's Avatar
bump
Old Feb 5, 2006 | 11:42 AM
4gencivicef9's Avatar
Can someone post a pic of where it bolts to ...... and has anyone tried the fullrace traction bars compared to this one?????
Old Feb 5, 2006 | 12:05 PM
Autoworks's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (4gencivicef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone post a pic of where it bolts to ...... and has anyone tried the fullrace traction bars compared to this one?????</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oceanic &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have a pic of how it cnnects to our car? its snowing here and I cant get to mine,I always though it was a sideways triagnel shape with 3 bolts on each side connecting them
So there isnt a huge problem removing them like out lca bolts? Fairly easy</TD></TR></TABLE>
just search "traction bar" in this forum.
There are alot of pics.
Old Feb 5, 2006 | 12:07 PM
LS_DON4500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Heres a tip,,put a jack under the crossmember to support it when you're taking the bolts off,,and use a long bar for leverage to get the bolts off..
Its really easy ,,Take the bolts off of the lca that hold on the radius arms then remove the bolts that hold the crossmember to the frame..</TD></TR></TABLE>
Old Feb 5, 2006 | 12:39 PM
shortyz21's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (LS_DON4500)
sometimes u gotta drop the shock fork off to be able to use an impact on the rod bolts. sometimes those are mad tite..
Old Feb 5, 2006 | 05:14 PM
PINKS's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (shortyz21)
My radius rods are disconnected right now anyways, just did a suspension upgrade
Old Feb 5, 2006 | 06:30 PM
caspers_hatch's Avatar
It would appear that it mounts in the same place the OEM unit would. If so, where did you get that and how much was it?
TIA!
Old Feb 5, 2006 | 06:36 PM
PINKS's Avatar
Default Re: Traction Bar Install - Oem Removal - How HARD Is It? (caspers_sfwd)
Its a local guy, he makes them for $250
kristo
Suspension & Brakes
Jul 11, 2015 01:46 AM
GSRCRXsi
34
Jul 29, 2011 02:26 AM
Jdmls
Sep 22, 2008 03:22 PM
obuhmyuh
Nov 21, 2007 08:46 PM
ctownintegra
Suspension & Brakes
Feb 4, 2005 04:43 PM
