CRX Sunroof Panel
Is it possible to remove the panel out of a car where you can not open the sunroof on? Car has no wiring harness, no way to open it.
Modified by CLE at 9:44 PM 2/4/2006
You can still open the sunroof.
Remove the cap on the headliner. Just behind the sunroof opening.
Then get the tool from the toolkit. (with the jack tools)
Insert the tool and rotate it.
It will open the sunroof manually.
do it like that if you are going to replace just the panel.
if you are taking out the whole assembly pull the headliner and the drain lines and drop it with the 10mm bolts that hold everything to the roof.
Headed back to the crx to pull the sunroof panel and managed to break both 8mm bolts by the rubber stoppers. Unfortunately the bottom side was rusted out on the panel I was gonna get.
What's the best way to take the panel off without damaging it, looks like im gonna fiber glass my rust damage.
gocivicgo
Jun 17, 2003 08:49 PM
