HELP: removing sticker marks on glass
Old Feb 4, 2006 | 07:41 PM
cilvia's Avatar
Default HELP: removing sticker marks on glass
the person who owned the car before me had some team sticker on the front window...and now it leaves a clean mark of the letters...its mostly noticable when i wipe a wet towel through it...does anyone know how to completely remove this??
Old Feb 4, 2006 | 07:49 PM
s13browe's Avatar
Default Re: HELP: removing sticker marks on glass (cilvia)
use a flat razor blade carefully not on tint though... theres also some kind of citrus stuff that works and is made for that...
Old Feb 4, 2006 | 07:59 PM
ZipTieGUy's Avatar
use a towel drench in some pretty hot water, put it over be a little patient then it will wipe or scrape off. just the the glass warm
Old Feb 4, 2006 | 08:02 PM
crxsiperf's Avatar
* B A N N E D *
Default Re: (ZipTieGuy)
Try some adhesive removers " OOPS" and "GOO GONE" They are citrus based and always worked well for me.
Old Feb 4, 2006 | 08:16 PM
M2nR's Avatar
Default Re: (crxsiperf)
y0 WD-40 works so0 go0d on that ****... its like its meant for that, just spray some on and just gently rub it off with your fingers
Old Feb 4, 2006 | 08:23 PM
Fenrir51's Avatar
Default Re: (M2nR22)
Try gun scrubby, i use it to clean guns but it will clean off sticker goo VERY easily, it will melt most plastics though if you get it on it Works really well
Old Feb 4, 2006 | 08:27 PM
Out of every
the sticky after stuff right? rubbing alcohol
Old Feb 4, 2006 | 08:32 PM
640K Crew's Avatar
i use aircraft paint remover on my glass to get paint and goo and other crap off. i dnt know if it can melt the glass if you leave it on long enough. i just spray some on a rag and wipe it down, then i use glass cleaner to clean it after. makes them crystal clear.
Old Feb 4, 2006 | 08:38 PM
Soccerking3000's Avatar
Default Re: HELP: removing sticker marks on glass (Drum and Bass Racing)
gasoline
Old Feb 4, 2006 | 10:45 PM
SoClose's Avatar
try using a heat gun on low . . thats what i used on my friends car but this was on his body though if u use it on ur body make sure the paint isnt to thin . . or less it'll just make smears of it and ruin the pain . . the window should be no problem and later just take some water and rubb off it off with some BOUNTY paper towels . .
Old Feb 4, 2006 | 11:13 PM
97_delsol_Vtec's Avatar
goo be gone should do the trick...scuff it out lightly with a razor then apply the goo be gone
Old Feb 4, 2006 | 11:19 PM
Boosted2000B16's Avatar
Default Re: (97_delsol_Vtec)
All you guys are missing the question here, he doesnt have any sticky goo or anything like that it is just a clean shadow or ghost of the original sticker! But on to your question man I dont know, I had a big NITTO sticker on my windshield one time and hade to remove to inspection, and I had the same problem. The only thing that worked for me was Father Time, after awhile it just went away, after numerous washes! Sorry no real answer.
Old Feb 4, 2006 | 11:30 PM
HondaEJ7's Avatar
if there was goo u would use goo gone and a hairdryer..but the shadow..i have no idea...sorry
Old Feb 5, 2006 | 06:47 AM
. a d a m's Avatar
Default Re: HELP: removing sticker marks on glass (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">gasoline</TD></TR></TABLE>
either that or Goo Gone
Old Feb 5, 2006 | 08:00 AM
that_vtec's Avatar
gasoline cant be left on long at all and it can NOT touch any trim or weather proofing but does work well. just be very careful. dont rush.....ive used windex to and it worked like a charm
Old Feb 5, 2006 | 08:10 AM
jboy08's Avatar
wd-40
Old Feb 5, 2006 | 12:38 PM
cilvia's Avatar
Default Re: (Boosted2000B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2000B16 &raquo;</TD></TR><TR><TD CLASS="quote">
All you guys are missing the question here, he doesnt have any sticky goo or anything like that it is just a clean shadow or ghost of the original sticker! But on to your question man I dont know, I had a big NITTO sticker on my windshield one time and hade to remove to inspection, and I had the same problem. The only thing that worked for me was Father Time, after awhile it just went away, after numerous washes! Sorry no real answer.</TD></TR></TABLE>
YES, im talkin about the ghost shadow of the sticker...NOT the sticky left overs from the sticker...but damn i just tried all kinds of window solutions laying around my house and wont come off... ...ima try and use a scunci steamer, MAYBE it might do somethin
Old Feb 5, 2006 | 01:20 PM
Default Re: (cilvia)
use claybar then
Old Feb 5, 2006 | 01:25 PM
barryyo's Avatar
Default Re: (Soccerking3000)
lighter fluid works well
Old Feb 5, 2006 | 11:47 PM
4g63tHBmonster's Avatar
Default Re: (barryyo)
Yeah use a claybar with some windex, or if that doesn't work use some mild laquer thinner and a razor. Watch out for the tint though, learned that the hard way one hung over day at work on a 06 acura TL good thing my boss wasn't around. haha
Old Feb 6, 2006 | 12:37 AM
nello a.'s Avatar
denatured alcohol. never had that problem though. sorry.
Old Feb 6, 2006 | 01:57 PM
YES, im talkin about the ghost shadow of the sticker...NOT the sticky left overs from the sticker...but damn i just tried all kinds of window solutions laying around my house and wont come off... ...ima try and use a scunci steamer, MAYBE it might do somethin [QUOTE=cilvia]
hey man let me know if that works out for you, it would be good to know if I ever ran into that problem again
Old Feb 6, 2006 | 02:02 PM
i'm telling you try claybaring it
Old Feb 6, 2006 | 02:17 PM
DaveSi677's Avatar
try rubbing alcohol
Old Feb 6, 2006 | 03:49 PM
sirshan's Avatar
Use this steal sponge looking thing from any autoparts store. Im drawing a blank, but it looks like a ball of fine wire, but soft...be careful with it because it can scratch your window...but its a trick I learned in autobody class...when you get overspray on windows...use this and it wipes it right off. Im sure a car parts store will know what Im talking about.
