Removing Ecu pins OBD0
Old Feb 4, 2006 | 06:19 PM
exsinnovation's Avatar
Default Removing Ecu pins OBD0
Who the hell do i remove the ecu pins..? anypictures of how to do it.? the black plugs are really hard. where exactly do i press?
Old Feb 4, 2006 | 07:26 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Removing Ecu pins OBD0 (exsinnovation)
they are a major PITA. i assume u got the green one done. the black are realy tricky. theres white "combs" holding in the wires. take theas out. 2 tabs on each side. once thease are out with a needle or glasses (juwleers) screwdriver, push in the center hole between the pins. push in the opposite of the pin your taking out. if it's top, push in/down. and wiggle the wire. with pratice it will come out. tool me bout 1/2 hour to figure it out.
Old Feb 4, 2006 | 07:33 PM
Any pictures?
Old Feb 5, 2006 | 08:45 PM
How about just splicing the wires into the conversion harness?
Old Feb 13, 2006 | 12:29 AM
ONG all you have to do is pull on the back of the pin where the wires are... with plier... wtf thats all you ppl had to say!
mortificationrock
14
Feb 1, 2008 12:22 PM
slo90si
Feb 16, 2006 01:37 PM
xXx Justin xXx
May 17, 2003 12:17 PM
91hondacrx
Mar 4, 2003 01:43 PM
EGHatchy
Jul 1, 2002 07:30 AM
