b16 swap code 14 ?
Old Feb 4, 2006 | 05:26 PM
90jdmcrxdude's Avatar
Default b16 swap code 14 ?
I did a b16a into my 90 crx DX and now I'm throwing a code 14 and I dont know how to get rid of it.... how can I get rid of it? Car is also running really rich... how can I fix that?
Old Feb 4, 2006 | 05:28 PM
RCautoworks's Avatar
Default Re: b16 swap code 14 ? (90jdmcrxdude)
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
Old Feb 4, 2006 | 05:33 PM
Default Re: b16 swap code 14 ? (90blackcrx)
Which sensor do I do this with.... theres two there?? Top or bottom?
Old Feb 4, 2006 | 05:38 PM
Its on the very back of the intake manifold, about 4 inches long.
rewerbcrx
Mar 13, 2006 05:06 PM
b16_madman
Jan 26, 2004 06:19 PM
untitled
Aug 26, 2003 04:07 PM
redrex91
Jul 28, 2003 03:39 AM
BoominD
Nov 25, 2002 10:55 PM
