d16y8 oil catch can/cannister hose connection?
Old Feb 4, 2006 | 05:14 PM
BigMoneyP's Avatar
Default d16y8 oil catch can/cannister hose connection?
Basically, I'm running a d16y8 turbo and need to find out if i need to connect that hose coming from the cannister behind the block. The hose can be pulled out easily and looks like it connects to the intake manifold. I'm currently using that spot for vacuum for my 3 car map sensor and my question is if it's ok to block off that hose coming from the back cannister and still be good? Is it necessary?
Old Feb 4, 2006 | 08:30 PM
ek_chris's Avatar
Default Re: d16y8 oil catch can/cannister hose connection? (BigMoneyP)
the pcv hose? that connects to the IM.
No it's not good to block that hose off.. you'll build to make crankcase pressure. Run it too your pre-turbo tube.. or an exhaust cut-off.. theres a thread about this
electronblueej8
Jan 9, 2016 06:47 PM
drynchristopher
Sep 2, 2013 08:25 PM
itsrooster
Jun 19, 2012 01:03 PM
kholmes
Sep 8, 2004 09:15 PM
Jim80y
Feb 28, 2002 02:20 PM
