GSR distributer (OBD1), axles, cams. 756cc injectors. P75 ECU. MSD cap, coil, plugs.
Old Feb 4, 2006 | 05:06 PM
rondigs's Avatar
Default GSR distributer (OBD1), axles, cams. 756cc injectors. P75 ECU. MSD cap, coil, plugs.
GSR Distributer (with MSD plugs-$72.00, cap-$59.00, and coil-$46.00) $175
OEM INTEGRA AXLES (ABS) $100
LS Crank Pulley $20
Dyno sheet from the distributer, cams and injectors
LOW Ohm PEAK AND HOLD 72lbs (756cc) SEIMEN DEKA INJECTORS $200 SOLD to blue89crx
GSR CAMS (2000) $65 SOLD to blue89crx
B16 Timing belt cover (PR3) SOLD
1995 Integra LS 5 speed ECU (P75) SOD to spooledhonda
Modified by rondigs at 10:13 PM 2/8/2006
Old Feb 5, 2006 | 09:12 AM
rondigs's Avatar
Default Re: GSR distributer (OBD1), axles, cams. 756cc injectors. P75 ECU. MSD cap, coil, plugs. (rondigs)
Super bowl sunday bump. Have fun. And if your drink'n; don't drive
Old Feb 5, 2006 | 06:05 PM
spooledhonda's Avatar
* B A N N E D *
i'll give ya 50 for the P75. i need it asap so plz hit me back
Old Feb 5, 2006 | 08:50 PM
rondigs's Avatar
Default Re: GSR distributer (spooledhonda)
$60 and its yours. All other PM's replied.
Old Feb 5, 2006 | 09:10 PM
* B A N N E D *
i left you a msg on your other page about your P75 i'll take it for $60
Old Feb 5, 2006 | 11:11 PM
DraginX's Avatar
Default Re: (spooledhonda)
Emailed you..
Old Feb 6, 2006 | 04:47 AM
rondigs's Avatar
Default Re: (DraginX)
Injectors and cams pending
Old Feb 6, 2006 | 05:55 AM
rondigs's Avatar
Default Re: (rondigs)
Timing belt cover sold to g2lsvtec
Old Feb 6, 2006 | 08:29 AM
rondigs's Avatar
PM's replied
Old Feb 6, 2006 | 08:00 PM
* B A N N E D *
did you get that pay pal up and runnin yet?????
Old Feb 7, 2006 | 04:05 AM
rondigs's Avatar
Paypal is up and running
Old Feb 7, 2006 | 11:06 AM
rondigs's Avatar
Thanks blue89crx
Old Feb 7, 2006 | 05:51 PM
rondigs's Avatar
Evening bump
Old Feb 8, 2006 | 08:20 AM
rondigs's Avatar
ECU sold to spooledhonda
Old Feb 8, 2006 | 07:14 PM
rondigs's Avatar
Fixed the pics. New host.
secondz
Mar 30, 2012 08:18 PM
justagsr
Jul 19, 2006 09:36 AM
