Integra seats in EF
Can I put 1996 LS integra seats in my EF? would I just need to put the EF rails on them? has anyone ever done this before? got any pics? also would this be the same for del sol seats?
yes use your ef rails... but you will most likely need to make a bracket for the seat to mount to the rails... i am not positive because i haven't tried it. i can't imagine that the seats have the same mounting points, they have totally different pans... ( i believe)
Well, if your "EF" is a crx than just swap the seat pans. That should do it.
Although, if you have a civic, I'm not sure how different the pans are from one another. I think the seat pan swap will work for either or.
On my rex, I just swapped seat pans and the seat back of the gsr seat I used just bolted right up to the bottom half.
SMOOTHN
48
May 9, 2023 06:19 AM
