Having a hard time telling which engine I have... Not stock head?
Old Feb 4, 2006 | 01:09 PM
SR20 Inside's Avatar
Default Having a hard time telling which engine I have... Not stock head?
Alright so my girlfriend bought a civic recently and it doesn't have any ex or dx on it so I am having a hard time telling which engine she has. From what I was able to gather the only vtec engine in 95 civics was the D16Z6. But I figured I would be able to see that stamped on the engine. I am wondering if perhaps at one point the previous owner of teh car blew the engine because it looks like there is a new head on it.
^^^ Looks like different head than was originally in the car unless stock honda engines come with the temp sensors.
^^ Only stamp I could find on the engine..
Old Feb 4, 2006 | 01:15 PM
spoonracer84eg's Avatar
Default Re: Having a hard time telling which engine I have... Not stock head? (SR20 Inside)
zc is the type motor. i do not know a lot about them. sorry
Old Feb 4, 2006 | 01:17 PM
veggiemaster's Avatar
Default Re: Having a hard time telling which engine I have... Not stock head? (spoonracer84eg)
yay for Sandy Utah! anyway, if im not mistaken, ZC's are normally DOHC 1.6's. What year of civic is it? that will tell you what motor is suppose to be in there.
Old Feb 4, 2006 | 01:22 PM
tallyturbo's Avatar
Default Re: Having a hard time telling which engine I have... Not stock head? (veggiemaster)
ya i though zc were usually dohc. maybe they just changes the head around
Old Feb 4, 2006 | 01:24 PM
turbotime's Avatar
88-91 CRX/Si
ZC/D16A8/9
16 Valve DOHC
1595cc
9.6:1 c.r
PGM-FI MPFI
137 bhp @6800
7200 rpm
108 lbft @ 5700
90-93 Integra LS/RS
ZC/D16A8/9
16 Valve DOHC
1595cc
9.6:1 c.r
PGM-FI MPFI
137 bhp @6800
7200 rpm
108 lbft @ 5700
90-91 Civic/CRX Si-R EF-8/9
ZC/B16A1
16 Valve DOHC VTEC
1595cc
10.4:1 c.r
PGM-FI MPFI
160 bhp @7600
8200 rpm
111 lbft @ 7000
Old Feb 4, 2006 | 01:25 PM
Rev2Eight's Avatar
Default Re: Having a hard time telling which engine I have... Not stock head? (tallyturbo)
http://www.hmotorsonline.com/s...30018
Possibly a SOHC ZC with a mini-me swap?
Old Feb 4, 2006 | 01:29 PM
Hrmmm interesting.
THe car is a '95.
From this link..
https://honda-tech.com/zero...33126
These are the engine specs that I found..
D16Z6
Displacement (cc): 1590
Power (bhp@rpm): 125@6600
Torque (ft/lbs@rpm): 106@5200
Compression Ratio: 9.2:1
Bore (mm): 75
Stroke (mm): 90
Cam Design: sohc
VTEC?: yes
OBD: 1
Year(s) Produced: 1992-1995
In the following car(s): Honda Civic EX/Si/Del Sol Si
What relevance does ZC have?
Old Feb 4, 2006 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> yay for Sandy Utah! anyway, if im not mistaken, ZC's are normally DOHC 1.6's. What year of civic is it? that will tell you what motor is suppose to be in there. </TD></TR></TABLE>
Where do you live at?
Old Feb 4, 2006 | 01:32 PM
turbotime's Avatar
does it have vtec? can you get a pic of the head from farther back, get the dizzy in the shot..
seems to be a DOHC with an SOHC head?! wtf
Old Feb 4, 2006 | 01:39 PM
Default Re: (turbotime)
Old Feb 4, 2006 | 01:41 PM
Looks like a really clean head compared to the rest of the engine. Looked under the oil cap and everything inside looks realllly clean.
This car according to the ODO has 170K on it
Old Feb 4, 2006 | 01:44 PM
jdmeg9's Avatar
Default Re: (SR20 Inside)
zc's do come in sohc. if you get a dohc and blow the head they are so hard to get that you end up having to settle for sohc. it is the only block honda made that you can swap like that.
jdmeg9's Avatar
Default Re: (jdmeg9)
i believe 92-95 sedans in japan had a trim level that had a zc in it
Old Feb 4, 2006 | 01:46 PM
doggworld1233's Avatar
i know this one!! take a pic of the head looking at the headers there are some stamping that have year and what kinda head it is.
justin
Well I am a bit confused. So as far as doing a tuneup with new plugs and wires etc... should I just go off of what Autozone has listed for the D16Z6? Or the EX model rather?
Old Feb 4, 2006 | 01:47 PM
Default Re: (doggworld1233)
There is nothing stamped on the heatshield over teh header if that is what you are thinking. Do you mean under the heatshield?
Old Feb 4, 2006 | 01:49 PM
also it is a VTEC Head you can see from the pic. not from the words on the valve cover.
justin
Old Feb 4, 2006 | 01:53 PM
My question wasn't whether it had vtec or not. I was concerned it had a newer head than was originally installed on the vehicle and I am having a hard time figuring it out.
Old Feb 4, 2006 | 01:56 PM
yea under the header shield. there should be a stamping. it will give you a year and some other numbers post them or take a pic and someone can tell you.
justin
Old Feb 4, 2006 | 02:07 PM
RaYnE's Avatar
were the d15b's stamped with zc??
Old Feb 4, 2006 | 02:28 PM
johnzm's Avatar
Default Re: (RaYnE)
UGH
yes its a SOHC VTEC. use a SOHV VTEC engine as your guide for parts (92 SI, 98 EX ect ect)
yes ZC's are sohc alot of the time. in fact id venture to say MOST if not ALL obd1 zc's are sohc.
and no, this is not the ONLY engine honda has ever made to take both a dohc and a sohc head. my moms JDM F22B has a DOHC head on it.
oh ya that bolt below the stamp on the motor taht attaches the trans looks loose. id tighten that.
Old Feb 4, 2006 | 02:33 PM
ABK's Avatar
ABK
Default Re: (johnzm)
1.6L SOHC OBDI D series, ZC in Japan. I US it's d16z6.
Old Feb 4, 2006 | 02:36 PM
Thanks for the info man I appreciate it. Thanks for pointing out that bolt too
Oh and all and all would you say that this engine is not the one that was originally in it seeing how that temp sensor is on the head?
Modified by SR20 Inside at 1:46 AM 2/5/2006
Old Feb 4, 2006 | 02:44 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SR20 Inside &raquo;</TD></TR><TR><TD CLASS="quote">
WOWZERS JDM BATMAN!!!!1111oneone
as said above, just use sohc vtec parts and you should be good
Old Feb 4, 2006 | 02:58 PM
johnzm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SR20 Inside &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info man I appreciate it. Thanks for pointing out that bolt too
Oh and all and all would you say that this engine is not the one that was originally in it seeing how that temp sensor is on the head?</TD></TR></TABLE>
it IS NOT a usdm motor. in other words no. that is not the original motor
