motor swap help?
Old Mar 25, 2002 | 09:17 AM
OldSchoolCrxSiR's Avatar
Default motor swap help?
i have a 1991 automatic dx hb my friend has a 91 si motor and tranny and he will sale it to me for $150 so can someone tell me what i will need to make the tranny and motor swap complete thanks for any help!
Old Mar 25, 2002 | 09:19 AM
Urban Business
Guest
Posts: n/a
Default Re: motor swap help? (HondaHb916)
you will need the shift linkage off of a manual hatch or crx. also you need the clutch pedal,cable and mounting hardware. an manual ecu is also needed. other than that the motor and trans should drop in.
Old Mar 25, 2002 | 09:20 AM
flat-blk-HB's Avatar
you will need his ECU,motor tranny,distr.,intake manifold,injector resistor box,etc...$150 sounds like a good deal is the motor in good shape??you also have to add wires to your ecu harness...DPFI to MPFI...very easy to do.... yeah shift linakge and that stuff too,clutch pedal assem.,clutch cable etc..
[Modified by 89EF-BCUMBIE, 12:22 PM 3/25/2002]
Old Mar 25, 2002 | 09:43 AM
Default Re: motor swap help? (89EF-BCUMBIE)
yeah the motor is in great shape he ran a 15.9 with it stock with his car stripped out so i am guessing for $150 i can have it and run high 15's low 16's stock but then i plan on modifying it so ho wmuch and where can i can a wiring harness cluch pedal shift linkage adn the other stuff i need
zeusdavis
Mar 22, 2011 10:16 AM
SirDreadsALot
Jan 6, 2011 09:09 PM
b18fool
Oct 26, 2005 03:08 PM
bananas
May 20, 2004 03:51 AM
CrXstEalin
Jan 19, 2004 10:49 PM
