Need to Buy ASAP: JDM ITR Sway bar Inner Brackets
I'm in need to buy ASAP the (2) inner brackets for the rear sway bar the one that mounts to the body. Acura does not sell this part but I don't know if the USDM ITR is the same size brackets I need?
Here is a picture on what I need with a arrow pointing at it
You need to replace the rear cross member or the entire sub frame for that. Maybe a frame/body shop could weld it up for you if you need a replacement.
