hid ballast plug question...
Old Feb 4, 2006 | 06:29 AM
da_rimrocka's Avatar
Default hid ballast plug question...
i just recently purchased a set of bmw 540 projectors and i own a 96 civic ex..now obviously the plug from the ballast doesnt match the plug from my harness..i know i can just splice the wires but the civic headlight plug has 3 wires and the bmw only has 2..i know 1 is +, 1 is -, but wut is the other wire for??
(hope u understood)
Old Feb 4, 2006 | 08:27 AM
Default Re: hid ballast plug question... (da_rimrocka)
no one knows??
Old Feb 4, 2006 | 08:57 AM
NrG's Avatar
NrG
what kind of ballast are they? Sounds like hella gen4. you'll get a better answer if you search hidplanet.com/forums/
Old Feb 4, 2006 | 09:18 AM
d-man88's Avatar
Default Re: (NrG)
3 wires, 1 for low beam, 1 for high beam, and 1 for ground. I would try and splice each one see which result you like the best. I would assume the BMW probably had two separate housings for high and low beam thus the reason there is one 2 wires whereas the civic has 3 because of integrated high and low beams.
Rodney Williams
Lighting
Oct 30, 2014 08:45 PM
my00civic
Lighting
Feb 24, 2011 08:25 AM
EvenStar
Jan 25, 2007 05:30 PM
hondaboy4life
Oct 30, 2006 12:35 PM
manyakiexpi
Honda Civic (2006 - 2015)
Apr 4, 2006 08:21 PM
