si handling vs gsr handling
Old Feb 4, 2006 | 12:08 AM
ZipTieGUy's Avatar
Default si handling vs gsr handling
aight i got a gsr but im getting a EG. I know the EG cant be faster so I just gonna make it better handling.
with full coil over set up, LCA and lower tie bar will an EG handle better than a stock Gsr? I know gsr is actually a "sprts" car and a civic is just well a civic hahah
Old Feb 4, 2006 | 12:11 AM
JDMsocalcivic's Avatar
Default Re: si handling vs gsr handling (ZipTieGuy)
of course the light car wins here no doubt
Old Feb 4, 2006 | 12:21 AM
blkSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMsocalcivic &raquo;</TD></TR><TR><TD CLASS="quote">of course the light car wins here no doubt </TD></TR></TABLE>
and the civic is not just a civic
Old Feb 4, 2006 | 02:10 AM
alwaysoverkill's Avatar
quality parts of the following:
1. 22mm rear sway bar from ITR with ASR subframe brace
2. Good coilovers or GC/Koni, no cheap ebay or no-name
3. good tires. I'm talking Azenis RT-615
those 3 and you'll get better handling then a Integra R...easily. Most of it will come from the tires.
forget, strut braces, forget tie bar (ASR acts as a tie bar anyways), forget that crap and focus one what will give you the biggest upgrade. The 3 things i've posted.
Old Feb 4, 2006 | 02:22 AM
RaceCarRyne's Avatar
Default Re: si handling vs gsr handling (alwaysoverkill)
i have 2 of the 3....i need a sway bar for my hatch....really swirly in the rear...does that sound right
it seemed like the rear wouldn't follow the front
i have
GC's on KYB 8 ways
and falken ziex's 50 series...
but no sways and only a front strut bar
i think i hvae a GSR sway bar for free coming from a friend so i'll use that and see what happens....sorry to thread jack
Old Feb 4, 2006 | 02:35 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: si handling vs gsr handling (DC2jdmIntegra)
when you REALLY start to mod the car, all your left with is which frame is stiffer, which has the shorter wheelbase, cause the Teg and EG's suspension are almost identical, front and reart suspension geometry is the same. So stiffen the EG cause its light, and there ya go. Now if your talking one vers another per cost per item, thats anothe story.
You WILL want a sway bar on the back of the EG, regardless of anything, it makes it SO much better to steer.
Old Feb 4, 2006 | 02:42 AM
Default Re: si handling vs gsr handling (Redline96LX)
well i had an EK..i have a delsol which is the same geometry as an EG really and it handles godlier better then my EK did...i wrecked my EK in part b/c my suspension wasn't solid and b/c of a carless driver...but i think i coulda save it had my car handled better...i'm not blaming my suspension because its not to blame...it was society haha....but i'd like my next one to handle better is all
Old Feb 4, 2006 | 12:52 PM
ZipTieGUy's Avatar
what kinda sway bar should i put on the eg then, I want somethign good but not to beefy it rips my frame apart
edit: I also heard EG has no holes for a sway bar? what do I do then
Old Feb 4, 2006 | 01:05 PM
dohcVTECeg2's Avatar
Default Re: (ZipTieGuy)
buy some omni LCA's
Old Feb 4, 2006 | 01:10 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">what kinda sway bar should i put on the eg then, I want somethign good but not to beefy it rips my frame apart
edit: I also heard EG has no holes for a sway bar? what do I do then</TD></TR></TABLE>
drill
Old Feb 4, 2006 | 01:22 PM
ZipTieGUy's Avatar
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">buy some omni LCA's</TD></TR></TABLE>
what about these, will they work for a sway bar
Old Feb 4, 2006 | 01:38 PM
DJ_Toocrazy's Avatar
you should put the gsr and the eg together and the end result should be a quick eg
Old Feb 4, 2006 | 02:49 PM
Brodie Bruce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">I know the EG cant be faster so I just gonna make it better handling.
Why can't it be faster?
roycivic92
Suspension & Brakes
May 22, 2010 09:04 PM
JDMCRX
Suspension & Brakes
Jul 10, 2009 11:04 AM
feeldabazzgsr
Suspension & Brakes
12
Dec 14, 2007 01:58 PM
BoRiCuA
Sep 28, 2006 05:22 PM
Bigmojoj27
Aug 22, 2005 01:01 PM
