what exactly do i have to do to fit dsm injectors in my 5th gen?
Old Feb 3, 2006 | 11:20 PM
bard329's Avatar
Default what exactly do i have to do to fit dsm injectors in my 5th gen?
i was offered a set of 440 dsm injectors real cheap and since my turbo is about to go in, i figured i'd take them.
i searched but all i could find was about installing them in OBD1... is it possible in my car?
Old Feb 4, 2006 | 06:47 AM
championshipwhite93si's Avatar
Default Re: what exactly do i have to do to fit dsm injectors in my 5th gen? (bard329)
i think you can but you are gonna have to have a resistor box. im not sure if the 5th gens got one or not, and you are gonna need a vafc to get your idle right too. there's more im just drawing a blank right now.
Old Feb 4, 2006 | 03:23 PM
bard329's Avatar
Default Re: what exactly do i have to do to fit dsm injectors in my 5th gen? (championshipwhite93si)
how would i find out if i have a resistor box? are they installed in the factory or do i have to get it aftermarket?
Old Feb 4, 2006 | 04:53 PM
yoluder's Avatar
i have the same setup. you can get a resistor box from earlier hondas. get a VAFC 'cause it will not idle at all without it. go to hondata.com for your resistor info.
Old Feb 5, 2006 | 08:23 PM
veganej's Avatar
those injectors should be peak and holds which would require a resistor box, 5th gens do not have resistor boxes bc they use saturated injectors. you can get one from a 4th gen that had an h23 or h22a1. or you can tell by using a voltmeter.
Old Feb 5, 2006 | 08:37 PM
bard329's Avatar
Default Re: what exactly do i have to do to fit dsm injectors in my 5th gen? (veganstraightedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veganstraightedge &raquo;</TD></TR><TR><TD CLASS="quote">those injectors should be peak and holds which would require a resistor box, 5th gens do not have resistor boxes bc they use saturated injectors. you can get one from a 4th gen that had an h23 or h22a1. or you can tell by using a voltmeter. </TD></TR></TABLE>
and what do i do with the resistor box? just wire it in (where?)
anyone gotta link to an install page?
b16ajdmrex
Apr 5, 2009 07:33 PM
boostedjdmdc2
Northwest (Sales)
Mar 20, 2008 10:59 PM
Excelerate
Mar 31, 2004 03:49 AM
sivik2nr
Jun 11, 2003 09:59 PM
accordexchange
Dec 10, 2002 02:29 AM
