HELP: fix dome light so that it turns on when door opens
the lights work when i switch it to on or off but when i leave it in the middle where its supposed to stay on untill my door closes doesnt work...anyone know how to fix this?? i got a 97 civic..thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">Check the door switch, the screw propably has come corosion on it so its not making contact.</TD></TR></TABLE>
if it did have corrosion and didnt make contact, wouldnt my alarm not know if my door is open or not when i arm it?? cause my alarm works properly...or is there another door switch thas connected with the light??
I have the same problem, but I have a multimeter. I checked it via the Helms book, switch is bad. Used one, 10$ on ebay.
if you have an aftermarket radio you have to put a jumper wire across the green plug behind your radio for the dome light to work with the door . I think the colors on the wires are lt. green/black, and lt. green/ red. jump them together and it should work. if these are the wrong colors some one correct me.
Really? WEll I do have a Kendood CD player. I don't know why Honda runs this kinda **** (keyless ignition) through its radios.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI »</TD></TR><TR><TD CLASS="quote">if you have an aftermarket radio you have to put a jumper wire across the green plug behind your radio for the dome light to work with the door . I think the colors on the wires are lt. green/black, and lt. green/ red. jump them together and it should work. if these are the wrong colors some one correct me.</TD></TR></TABLE>
Yes. If you have an aftermarket radio on your honda. The Dome light stops working and you have to do something like that posted Above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">Really? WEll I do have a Kendood CD player. I don't know why Honda runs this kinda **** (keyless ignition) through its radios.</TD></TR></TABLE>
Yeah, it just turns out bein a huge hassle. It took me a while to figure out it was my deck that was screwin with my ek's dome light. Atleast they arent as bad as VWs
what if i still got the stock deck still in??
can speaker wire be used as a jumper wire for this to connect those wires together?? or what do i use to connect them?? what kind of wire is it called?
Silent_Destruct
Nov 26, 2006 07:02 PM
TehMoonRulz
Jun 29, 2005 09:31 AM
