88 civc hb driver side shakes
Old Feb 3, 2006 | 09:53 PM
civic889802's Avatar
Default 88 civc hb driver side shakes
i have a problem with the driver side seems to shake way 2 much when i take of n when i am stoping does any one have any ideas i change the knuckles to the 91 knuckles if any one can help me i be thankfull
Old Feb 3, 2006 | 10:03 PM
shadycrx's Avatar
Default Re: 88 civc hb driver side shakes (civic889802)
i have same problem after switching knuckles but i think its because of warped rotors
Old Feb 3, 2006 | 10:05 PM
Default Re: 88 civc hb driver side shakes (shadycrx)
i have brand new rotors n shakes bad n makes my engine move bad
Old Feb 3, 2006 | 10:14 PM
Jay.D.Em!'s Avatar
check your mounts maybe u have a blown or shot motor mount? also could be the wheel bearing or tie rod end..
Old Feb 3, 2006 | 10:48 PM
Shelton's Avatar
Default Re: 88 civc hb driver side shakes (ILoveMyED6)
I had a shaky problem in my ef... my axle nuts were comin loose and my rotors got tore up I had to pump for he brakes o come on.... had a couple close misses wih some nice cars including a mercedes
Old Feb 3, 2006 | 10:54 PM
square_1's Avatar
My car shakes a ton too. But then when I put it into neutral the shaking stops. It also has a little clunk on its downshift at 20 MPH. I think it is because my rear motor mount is out. I would check yours.
street_ride14
Jun 22, 2012 01:56 AM
jasonacura91
16
Apr 12, 2009 04:21 PM
bbunz
Dec 19, 2007 05:31 PM
19992civichatch
11
Jan 10, 2007 10:42 PM
T--Rex
May 12, 2005 02:22 PM
