Balljoint camber kit
Old Feb 3, 2006 | 09:44 PM
masteryoda10's Avatar
Default Balljoint camber kit
I put a camber kit on the front balljoints of my 94 accord. I do not know how to ajdust camber though. Can anyone help?
Old Feb 12, 2006 | 10:01 AM
Default Re: Balljoint camber kit (masteryoda10)
bump
Old Feb 12, 2006 | 02:49 PM
hondadude's Avatar
Best to have this done on an alignment machine; moving both the adjusters in or out the same amount is the way to change the camber. The camber is usually set AFTER the caster has been set up. The way to adjust caster is by way of adjusting the adjusters in or out depending on the caster being negative or positive.
Some parts stores will have a magnet with a level sticking out from it that can be used to get the camber "in the ballpark".
Old Feb 12, 2006 | 04:33 PM
P_Adams's Avatar
Default Re: Balljoint camber kit (hondadude)
I have to agree with Hondadude, It's best that you have an alignment shop perform the adjustment. You're choice of the adjustable Ball Joint makes the adjusting process less Fu**d up, but you don't have the proper tools to measure the camber angle.
I've see some make a fixture for a carpenters level which would allow it to reference off the rim bead, and set the Camber angle that way, but it's very imprecise when compared to modern Bear or other Alignment Equipment.
P
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
msinsky14
Apr 16, 2006 01:08 PM
mattdenali
Suspension & Brakes
May 26, 2005 09:21 PM
mingbling
Jul 28, 2004 02:35 AM
Mike36
Feb 3, 2003 04:55 PM
