2.0 Ls/Vtec Fully Built Engine Setup for Sale - Capable of over 650hp
I have not been able to sell the car as a whole so I am going to try the engine setup. If you are interested send me an email or call me at 408 482 9442. I want to sell everything as a drop in kit including some of the electronics and the exhaust system w axles and everything.
Engine Block
LS Block 2.0L – Block $400
Thermal Dispersant Coated Block Exterior - $150
RS Sleeves Open Deck Iron Ductile Sleeves – 84.5mm - $900
Weisco 9:1 Compression Thermal Coated and Dry Film Coated Pistons - $400
Balanced LS Crank - $400
King Race Bearings - $100
Eagle Connecting Rods – Balanced - $400
ARP Rod Bolts and Head Studs -$100
Golden Eagle Oil Distribution Block Adapter - $75
Energy Suspension Engine Mounts - $50
Energy Dynamics Engine Breather Kit - $175
Drilled and Tapped Knock Sensor - $40
High Output Rewound Alternator - $150
New Honda Oil Pump and Water Pump - $125
Z10 5 quart Baffled Oil Pan and Pickup - $400
Block Assembly: $725
Block Total: $4590
Engine Head
GSR Head Cast - $300
Thermal Dispersant Coated Head Exterior - $100
Port-Flow Stage 3 Port and Polish - $700
Port-Flow High Pressure Springs - $200
Port-Flow Titanium Retainers - $200
Supertech .5mm oversized Intake Valves - $120
Supertech .5mm oversized Inconel Exhaust Valves - $145
Thermal Barrier Coated Valves and Combustion Chamber - $150
Cosmetic MLS Head Gasket - $150
RC Engineering 720cc Injectors - $300
JG Edelbrock Intake Manifold – Thermal Dispersant Coated - $300
Crower Stage 2 Turbo Cams - $700
STR Fuel Rail - $150
STR Cam Gears - $150
JDM Integra Valve Cover - $150
Mugen Oil Cap - $50
Head Total: $3865
Turbo Kit
Thermal Barrier Coated LoveFab Tubular Manifold and Downpipe - $1500 total
Thermal Barrier Coated T-61 Turbo - $900
Thermal Barrier Coated Tial 46mm Waste gate - $300
Thermal Dispersant Coated Spearco Intercooler - $500
Thermal Dispersant Coated Intercooler Piping - $200
Blitz Blow-off Valve - $150
Custom Bozz-Speed full 3in Titanium Downpipe Back Exhaust - $1500
Hose Techniques T-Clamps and Silicon Couplers - $150
Greddy Profec-B Boost Controller with Steering Wheel Remote - $250
HKS Air Filter - $150
Turbo Kit Total: $5600
Transmission
Integra LS Transmission - $400
ATS 16 Plate Differential - $1100
Clutchmasters Stage 3 Clutch - $350
Clutchmasters Aluminum Flywheel - $250
ARP Flywheel Bolts - $30
Energy Suspension Shifter Mounts - $20
Transmission Total: $2150
Miscellaneous Engine
Hondata Stage 4b, now S100 chip - $500
P73 ECU with obd1 Conversion - $300
GM 3 bar Map Sensor - $90
C&R Aluminum Radiator – Thermal Dispersant Coated - $400
Cusco Oil Catch Can – Valve Cover - $90
MDS 6A Ignition - $100
NGK Spark Wires - $100
MSD Blaster Ignition Coil - $50
J&S Ultra Safeguard - $400
Miscellaneous Total: $2030
Engine Block
Block Total: $4590
Engine Head
Mugen Oil Cap - $50
Head Total: $3865
Turbo Kit
Transmission
HOLY HOT DAMN.... very nice setup, i dont even want to know the amount of time invested in that R.. hope you dont mind im gonna try some of your ideas i see there
B18 CYA
Dec 19, 2006 03:50 PM
FS: Built LS Block (b18a) Built GSR Head, Twin Plate, Fluidampr, OS Giken, Darton, CP, Manley, Golde
wantboost
Sep 2, 2006 06:48 PM
400WHPITR
Jan 30, 2006 11:25 AM
