Hybrid Engine Harness obd0/obd1
Old Feb 3, 2006 | 02:12 PM
SupraRXZ's Avatar
Default Hybrid Engine Harness obd0/obd1
I got a project im working on a 90 Civic Hatch DPFI, I am putting in a b18b1 block, I want everthing converted to MPFI OBD0, execpt for the injectors which I want to be obd1, So I dont have to used a resistor box. So Is it possible to wire up the obd1 injectors with obd1 clips and then keep the rest obd0?
Old Feb 3, 2006 | 02:15 PM
crxnj's Avatar
Default Re: Hybrid Engine Harness obd0/obd1 (SupraRXZ)
yeah you can run those saturted injectors as long as you dont use a resistor box,, just solder the wires together..
lilsicsoul
Jan 22, 2009 09:31 PM
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
91lsteg
May 15, 2005 11:32 AM
dpine
Jul 14, 2004 06:19 PM
