swap motor from 98 accord to 96
Old Feb 3, 2006 | 02:08 PM
cdx280's Avatar
Default swap motor from 98 accord to 96
Would the 2.3l vtec from a 4 door 98 accord ex be able to fit into a 2 door 2.2L vtec 96 accord. if so what would be required to do the swap? i tried searching but turned up with nothing.
Old Feb 3, 2006 | 02:15 PM
BlkChryKord's Avatar
Default Re: swap motor from 98 accord to 96 (cdx280)
There might be some minor differences but it should be a straight swap considering they're practicly the same motor.
Old Feb 3, 2006 | 02:16 PM
cdx280's Avatar
Default Re: swap motor from 98 accord to 96 (BlkChryKord)
so will it bolt up to the same transmission and run off the same ecu?
Old Feb 3, 2006 | 04:03 PM
cdx280's Avatar
anybody?
bump
Old Feb 3, 2006 | 05:22 PM
SneezinCD5's Avatar
Should drop right in. I was going to do an F23/H23 head in my 95 but decided to just put it on the F22. You shuldn't have to worry about much since the VTEC is already ran. Heard the F23 is just as good as the F22
Old Feb 6, 2006 | 06:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdx280 &raquo;</TD></TR><TR><TD CLASS="quote">so will it bolt up to the same transmission and run off the same ecu?</TD></TR></TABLE>
Yes
95OdyLX
Mar 5, 2007 08:57 PM
choppdnscrwd
Nov 22, 2005 07:37 PM
Jdm Dina
Apr 25, 2005 04:42 PM
mingbling96
Mar 7, 2005 11:12 PM
