injectors
Old Feb 3, 2006 | 01:46 PM
crxcrazysi's Avatar
Default injectors
what is the best injector for my n/a jdm b16a motor and is the oe fuel pump good enough with say 440's if i would go that way
Old Feb 3, 2006 | 01:57 PM
crxnj's Avatar
Default Re: injectors (crxcrazysi)
How much power are you making and how high are you revving?
Stock injectors and pump should be fine,,but you should look into the gsr fuel pump,,flows 134lph and can be had cheap..nice and queit and the dohc vtec engine wont lean out in the upper rpm anymore like it does with the stock 79lph pump..
Old Feb 3, 2006 | 03:22 PM
crxcrazysi's Avatar
Default Re: injectors (Mr.speaker)
right now about 180hp plan to rebuild head with cams but my main issue right now is bogging at lower revs in each gear
B16a2Em1
Oct 16, 2015 04:20 PM
Serdar
10
Jul 8, 2015 06:48 PM
Evans-Tuning.com
Oct 4, 2010 07:08 PM
Evans-Tuning.com
Performance
12
Jun 1, 2009 05:04 PM
Terrible One
Jun 3, 2006 09:01 AM
