What Size Tires?
Old Feb 3, 2006 | 01:22 PM
classified's Avatar
Default What Size Tires?
Should I run 215/40/17's on my 5th gen lude or 215/45/17's????
What are the pros and cons of each?
Old Feb 3, 2006 | 01:29 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: What Size Tires? (spirctsae)
Do the math.
40% of 215mm is a 86.00mm sidewall.
45% of 215mm is a 96.75mm sidewall.
Your overall tire height will differ by approximately 21.50mm or approximately 0.85inches
Or your vehicle will sit about 0.43inches higher.
Old Feb 3, 2006 | 01:31 PM
BB6racer's Avatar
215/40 is the recommended size. 215/45 would have a larger side wall, and overall diameter. which would also throw off your speedometer, odometer, and your gearing will be slightly different too, plus i think you would run into rubbing issues. i have 205/45 and they feal really good, if you'd like to try that size out too.
Old Feb 3, 2006 | 01:54 PM
classified's Avatar
A 215/40 will throw off my speedo ect. as well. Everywhere I go websites claim that a 45 tire is what I "should" be running with a 17inch wheel.
Old Feb 3, 2006 | 02:00 PM
ScareyH22A's Avatar
Community Builder
Default Re: (spirctsae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirctsae &raquo;</TD></TR><TR><TD CLASS="quote">Everywhere I go websites claim that a 45 tire is what I "should" be running with a 17inch wheel. </TD></TR></TABLE>
Yea but it would look dorky.
Old Feb 3, 2006 | 02:12 PM
classified's Avatar
Default Re: (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly looks dorky about this wheel/tire size combo?
Old Feb 3, 2006 | 02:40 PM
hu's Avatar
hu
I would go with the 40 series to keep as small of a diameter as possible.
Old Feb 3, 2006 | 03:53 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirctsae &raquo;</TD></TR><TR><TD CLASS="quote">What exactly looks dorky about this wheel/tire size combo?
I thought you were asking how it'd look on a prelude?
Old Feb 3, 2006 | 05:08 PM
classified's Avatar
It doesn't matter what car you put it on a 215/45/17 tire/wheel never looks "goofy" that's my point. Just keep telling yourself that .4 inches of sidewall difference will make a car look "goofy"
Old Feb 3, 2006 | 05:47 PM
LINK76's Avatar
be on the goofy part. wouldn't the 45 allow better ride comfort and less chassis warpage knowing that the prelude is a rigid car to begin with........anyhow the larger diameter wheel will give you a better 1/4 time. In other words shorten your gear ratios.
Old Feb 3, 2006 | 06:39 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirctsae &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't matter what car you put it on a 215/45/17 tire/wheel never looks "goofy" that's my point. Just keep telling yourself that .4 inches of sidewall difference will make a car look "goofy" </TD></TR></TABLE>
Ok. Go do what you gotta do then. But I'm telling you, I've tried that combo and it looked goofy. Maybe my car was too low. I guess if you're car is almost stock height then a taller tire would be better for you.
Old Feb 3, 2006 | 06:44 PM
classified's Avatar
1.5inch drop compliments of sport springs and 5-way tokico illuminas.
Old Feb 3, 2006 | 06:46 PM
ScareyH22A's Avatar
Community Builder
I run 215/45-16's now w/Eibach Pro Kit 1.3" or so on Tokico Illuminas. I have about 1 finger gap.
Old Feb 3, 2006 | 06:50 PM
classified's Avatar
Got any pix?
Old Feb 3, 2006 | 07:22 PM
The Weather Man's Avatar
Yep. A thicker sidewall would make the ride more comfortable. Having a small sidewall and a good suspension is kinda counter-productive........
Old Feb 3, 2006 | 07:48 PM
Uhkordguy's Avatar
215-40-17 would be closest to the stock diameter.
Nbboy7
Apr 12, 2008 05:38 PM
SupaFly_Honda
Feb 14, 2008 04:54 PM
CeNCaL-DA9
Sep 4, 2007 09:10 PM
HuskerHybrid
Aug 26, 2005 06:58 PM
ludewithanh22
Jun 26, 2005 02:16 AM
