**Need help diagnosing problem**
Old Feb 3, 2006 | 12:54 PM
Ash81's Avatar
Default **Need help diagnosing problem**
Car does not want to go its jerks like at 1k -2k rpm then when it gets pass 3k cars takes off and does not jerk....it happens through all the gears 1-5................so basically car jerks at low rpm then when pass 3k it drives normal.........any help appreciated.
Old Feb 3, 2006 | 01:00 PM
poison's Avatar
Default Re: **Need help diagnosing problem** (Ash81)
What car?
What mods?
For basics.. check your spark plug conditions, check distributor cap/rotor.
It also could be bad gas.
Old Feb 3, 2006 | 01:16 PM
Ash81's Avatar
Default Re: **Need help diagnosing problem** (poison)
i have a 95 civic with a b16a2 with intake.....
i was thinking about bad gas....but what about the vtec.....someone told me about it being at stuck or something but my car is not throwing that code at first it was throwing fuel injector code so i cleaned all the injectors its still doing the same problem.
Old Feb 3, 2006 | 01:29 PM
Luserkid's Avatar
Tune up sounds like a must. Or your timing is way off. Did you play with your timing belt?
Old Feb 3, 2006 | 01:43 PM
Ash81's Avatar
Default Re: **Need help diagnosing problem** (Luserkid)
ive done a tune up dont know how my timing is off ive never touched my timing belt.......
pimpwagon
Nov 12, 2010 08:41 AM
smokey68321
Apr 18, 2010 05:20 PM
duthie14
Apr 21, 2009 01:15 PM
all stock
Jan 7, 2004 01:40 PM
Audi A4
May 25, 2002 12:12 PM
