93 Integra ls se w/B20/J1 b16 tranny........what alternator?
Old Feb 3, 2006 | 11:06 AM
hondakid0114's Avatar
Default 93 Integra ls se w/B20/J1 b16 tranny........what alternator?
I had a 93 Integra ls se automatic but got a B20/J1 b16 tranny swap........i dno which alternator i need bc the people did a shitty job im tryin to fix it my self but i need some help A N Y B O D Y K N O W?
im new to this stuff
Old Feb 3, 2006 | 11:19 AM
TurdBlown Teg's Avatar
any distibuter from 92 - 95 should work, since it is still obd1 correct? if its obd2 then you need a distributer from 96-01 from either a crv or an integra.
Old Feb 3, 2006 | 01:26 PM
nickG's Avatar
Default Re: 93 Integra ls se w/B20/J1 b16 tranny........what alternator? (hondakid0114)
id think you need one for your 93 ls...a 5sp if it makes a difference...
since a b20 is basically an b18a...it should be the same..
check out the teg tips on g2ic.com for sure tho
Old Feb 7, 2006 | 06:34 PM
Default Re: (kevin716)
its a 97 b20b but the car is a 93 ls special
LS94tegra
Sep 27, 2009 12:13 PM
nitty banthin
Jul 6, 2009 09:31 AM
B20VTEG
Mar 20, 2005 07:33 AM
