Rebuilding a H23
Old Feb 3, 2006 | 10:40 AM
uneek4dr's Avatar
Default Rebuilding a H23
What can I upgrade while the head is apart that will give me some performance gains without having to do anything to the bottom end or cause me to have to buy a new ECU or chip it? I'm on a budget build so I dont want some insane setup just something better than stock but not crazy to the point of having to invest $600-1k more just to accomodate the upgrades to the head. Thanks for any input
So far I am getting new valves/springs/retainers, want a set of cams but unsure what to get without needing to chip the ecu or mess with anything else.
Old Feb 3, 2006 | 10:43 AM
hu's Avatar
hu
Default Re: Rebuilding a H23 (uneek4dr)
Since you are taking the time to get cams & valvetrain, why not get a port & polish on the head? Think about a good header and exhaust system as well.
Old Feb 3, 2006 | 11:01 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr &raquo;</TD></TR><TR><TD CLASS="quote">
So far I am getting new valves/springs/retainers, want a set of cams but unsure what to get without needing to chip the ecu or mess with anything else.</TD></TR></TABLE>
New as in OEM or aftermarket valvetrain?
Old Feb 3, 2006 | 11:37 AM
PirateMcFred's Avatar
High compression aftermarket valves, port and polish, tighter vlave lash, thinner headgasket, maybe advance the distributor a little bit. I would say install H22A1 pistons but you said that you didn't want to touch the block. Any major cam upgrade will require a retune. As it is compression and a header are your friends.
Pirate
Old Feb 3, 2006 | 08:42 PM
uneek4dr's Avatar
Default Re: Rebuilding a H23 (SKDRCR)
aftermarket, my friend can get good prices on ferrara valves and such so we will see
Old Feb 4, 2006 | 06:58 AM
championshipwhite93si's Avatar
stage two cams and gears....i/h/e
jprelude92
Jan 11, 2009 08:08 PM
k24a4kid
Aug 10, 2005 06:46 AM
polishprinze
Jan 25, 2005 10:49 AM
hon-derr
Jan 11, 2005 01:31 AM
dflipmode
Apr 15, 2002 06:55 AM
