who's boosted with an eg radiator?
i have an ef civic and now that i went with a bigger turbo my stock rad. wont fit, so im think of using an ef rad. but how would my cooling be? with a smaller rad. and a turbo still close to the rad. im kinda worried that it might not cool enough.....so anyone with experience let me know how well it would cool---thanks
people use it all the time, its like the only thing u could do really.
Ebay sells EG style rad. that are 3" thick and are only 100$All alluminum
you will be fine..the smaller rad is actually twice as thick so its has pretty the same amount of cooling as the longer one that is half as thick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Black »</TD></TR><TR><TD CLASS="quote">you will be fine..the smaller rad is actually twice as thick so its has pretty the same amount of cooling as the longer one that is half as thick. </TD></TR></TABLE>really it doesnt look twice as thick? and i was told just because the rad. is thicker doesnt mean it will cool as good (it has 1/2 the cooling area)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">people use it all the time, its like the only thing u could do really.
Ebay sells EG style rad. that are 3" thick and are only 100$All alluminum</TD></TR></TABLE>would i stock replacement work? i can get an eg (new ) for $55
you can get dual core eg rads for $40 shipped new off ebay, not aluminum
On an ef, youll have to throw a gangster lean to close your hood or get a aftermarket crossmember
I just hacked a bit of the stock crossmemeber at the front for clearance and it worked
Thats on a 88 si
Thats on a 88 si
Mine is the duel core. It is twice as thick. True it doesn't have the surface area that a full length stock crx rad has but the duel core will cool the boosted motor sufficiently. I have been running mine for 3 years at 10lbs supercharged and now turbo charged, without one problem. I use a good 12" fan as well which is just as important.
hybridmiklo
Jan 24, 2007 10:53 AM
