94/95 valve cover swap w/96-01
Old Feb 3, 2006 | 08:46 AM
I3lakeintegra's Avatar
Default 94/95 valve cover swap w/96-01
i was wondering what i need to do to be able to put the 96-01 b18b valve cover on my 95 integra. i like this valve cover alot better and i asked on another forum that it would work. But no one said what i needed to do to make it work. i was thinking maybe something with the pcv system i might have to change. any input would help. thanks!
Old Feb 3, 2006 | 09:05 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: 94/95 valve cover swap w/96-01 (I3lakeintegra)
I Think the only thing different is between the valve cover & IM.
The line that is on top of the 96+ valve cover in the middle,
normaly goes in through the IM on the 94-95.
So maybe if you plug the hole on the older IM it could work,
I'm not sure though, if on the older engine it would change anything from running that line through the valve cover.
Old Feb 3, 2006 | 02:03 PM
integra_papa's Avatar
just put a plug in the top of the valve cover where the pcv valve would go. its a lil black plug. keep the oem pcv valve where it is dont move it. the 96-01 ls valve cover is alot nicer
Old Feb 3, 2006 | 09:46 PM
Default Re: 94/95 valve cover swap w/96-01 (integra_papa)
thanks for the replies...what kind of plug should i use?
Old Feb 4, 2006 | 05:52 AM
Hype-R Stalker
any kind of rubber plug that won't be able to get sucked in.
Old Feb 4, 2006 | 08:41 AM
Default Re: 94/95 valve cover swap w/96-01 (FlatBlackTeg)
would a breather work?
miahjera04
Nov 22, 2018 10:06 AM
stackz
Oct 13, 2005 11:05 AM
DOHC-DX
Sep 8, 2002 04:41 PM
