Answer me these 3 questions: Tranny removal, Pistons Removal, LSD Removal
Old Feb 3, 2006 | 08:04 AM
turbotime's Avatar
Default Answer me these 3 questions: Tranny removal, Pistons Removal, LSD Removal
Ok I dont need a lot of detail but I have 3 questions:
1. When seperating a tranny from an engine, does anything special need to be done other than removing the tranny bolts and pulling the tranny off? What about installing the tranny on a new engine, does it jsut bolt right up?
2. What is the easiest way to remove the pistons with the head off? Do you pull the piston and rod out thru the tup of the block or thru the bottom?
3. I want to double check my LSD, once i have the tranny off of the block, how hard is it to get to the LSD? I have a obx lsd, it is quaife-style as far as install goes...
thanks
Old Feb 3, 2006 | 08:12 AM
Squelch's Avatar
Default Re: Answer me these 3 questions: Tranny removal, Pistons Removal, LSD Removal (turbotime)
bump
Old Feb 3, 2006 | 11:59 AM
turbotime's Avatar
thanks, bump again
this is basic stuff cmon guys!
Old Feb 3, 2006 | 01:21 PM
93accordNOS's Avatar
1. You'll need to remove all electrical connections on the trans (VSS reverse lights) and shift linkage.
2. Yes pull the piston out the top of the block.
3. You will need to remove both the main shaft and the countershaft of the trans to get the diff out.
Old Feb 3, 2006 | 01:26 PM
Luserkid's Avatar
Default Re: (93accordNOS)
1. Strip the tranny completely while its on the motor. Make sure nothings attached. Then start from the bottom up taking all the bolts off. Put a pillow or something soft under the tranny and when you pull it free from the motor just drop it on the pillow. It helps alot if you have the starter off.
2. You cant pull the pistons from the bottom only the top. When you disassemble from the bottom remember what color code the bearings are so you could put them back in the same way.
3. I hate transmission work and so will you after you do that.
Old Feb 3, 2006 | 07:04 PM
hatchi's Avatar
1) Dont forget to pull the clip on the top of the casing besides the bolts only
Old Feb 3, 2006 | 07:13 PM
turbotime's Avatar
Default Re: Answer me these 3 questions: Tranny removal, Pistons Removal, LSD Removal (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">1) Dont forget to pull the clip on the top of the casing besides the bolts only</TD></TR></TABLE>
can you elaborate?
Thanks for the ehlp everyone, seems like the process is pretty straightforward. I am getting new bearing for the new build so do i still need to pay attention to bearing codes in disassembly?
Also for the pistons removal, i have aftermarket rods (crowler) can i still just pull the pistons and rods out thru the top?
LSD removal sounds a bit tricky- ill make a new post for that once i got the tranny off
Old Feb 5, 2006 | 08:57 PM
Squelch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
LSD removal sounds a bit tricky- ill make a new post for that once i got the tranny off </TD></TR></TABLE>
pics if possible. i'd like to know how this will look like
good luck
ashb82
Transmission & Drivetrain
Oct 6, 2010 03:30 PM
taffywhtb16
14
Mar 24, 2010 10:13 AM
dohc_profile
Jan 8, 2007 05:26 PM
turbotime
Mar 24, 2006 08:36 PM
