Oil Leak... need some help
Old Feb 3, 2006 | 07:18 AM
Muad'Dib's Avatar
Corr Performance Pilot
Default Oil Leak... need some help
ok. here is my situation. I broke a timining belt on the car but the car was not moving on the road. It was just about to get going when it happened. We take the head off and take it to a machine shop. No valve damage or impact with the pistons. ok. so we assemble the engine and right after we run it for a few seconds we get a leak at the head gasket on the passanger side in the back corner.
We take the head out again and figure out we had the head gasket on backwards. No problem. we flip the HG around and put the head back on. start the car, runs like a champ. 10 minutes after leaving it there running, we see a leak now on the front side of the engine, right corner, on the head gasket. this time the coolant had mixed withe the oil. so we take the head out and sure enough there is that milky stuff all in the head and also in the oil pan. we figured that we had crushed the head gasket when it was on backwards the first time and now its leaking on the same corner but on the opposite side where it was the first time.
We then get a new head gasket and put the thing back together. as we start it, bam....same leak in the same place as before but we didnt see any coolant mixed with it. Perhaps it wasnt mixing just yet. I'm not really sure what the hell could be wrong with the engine. Could the head be warped? I'm taking the head off right now and bringing it to my friend's machine shop to see what it could be. any ideas would be appreciated. thanks
Old Feb 3, 2006 | 07:23 AM
Muckman's Avatar
Moderator in Chief
Default Re: Oil Leak... need some help (Muad'Dib)
My first guess is the head dowels used to center the head on the block. If one is cocked or in the wrong hole it would prevent the head from sitting firmly.
But since it happened twice, in a different area, with a new head gasket. I would look towards getting the head milled.
fourdoorteg
Jan 21, 2010 07:15 PM
rc90hatch
Jan 10, 2006 05:49 PM
strsi
Apr 6, 2005 05:28 PM
InfamousRS
Jun 2, 2002 08:21 AM
