crx with d-series swap
I will work, but you have to use an 88 clutch/flywheel.
The 88 tranny has a different number of splines than newer trannies. The tranny will bolt up to that motor fine.
you can still use a 220mm clutch if you use the flywheel and pressure plate from the z6 (90+ pressure plate and flywheel) if you use a clutch from an 85-87 prelude Si its a 220mm clutch with 21 splines...
i personaly didint feel comftorable putting 200whp on a 200mm clutch so thats what i did when bolting up my 89 si tranny to my d15b
ParistsCP
Oct 7, 2008 06:59 AM
eur0
May 20, 2003 09:05 PM
DsMWookie
Sep 18, 2002 09:49 PM
