crx sputters
Old Feb 3, 2006 | 05:35 AM
kantfadedisazn's Avatar
Default crx sputters
my 88crx hf sputters when i start the car and tap on the gas a bit, but when its above 1000rpm its ok it just happens when i give it a bit of gass, it has a jdm zc sohc swap, ima using a 89 pm6 ecu, and the check engine light is on to, but the coolant sensor and the oxygen sensor was replaced, so i dont know what the problem is, could it be the ecu cuz the wiring at first was wrong , could that hav slightly fried the ecu, it starts, but that sputtering is weird and the check engine light is on, i dont knw what it can be. if anybody can help me please do
Old Feb 3, 2006 | 05:36 AM
Default Re: crx sputters (kantfadedisazn)
help me please
Old Feb 3, 2006 | 05:55 AM
Default Re: (goCRXgo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goCRXgo &raquo;</TD></TR><TR><TD CLASS="quote">I once had a similar problem, my car would make a puttering sound, like something was wrong with the compression, and wouldn't accelerate properly til about 2000RPM's. I was frantic as I was bout to sell the car, and since it started doin that, I figured I'd make it look better for the buyer by changin out the messed up valve cover on it for a newer cleaner one. When I did, I swapped the gaskets too. Long story short, the guy bought a car that doesnt putter, and my other CRX now has the ugly cover and the puttering problem. So for me, the solution was a new valve cover gasket. If this sounds similar to your car's problem, give it a try, their an easy fix, and relativly cheap
Or better yet, just remove your valve cover and check your VC gasket, if it looks rough, that could be it???</TD></TR></TABLE>
I GUESS BUT HOW ABOUT THE CHECK ENGINE LIGHT, I THINK THAT IS WHATS CAUSING IT I DONT KNOW THO, COULD THE ECU BE PARTIAL FRIED OR MESSED UP
Old Feb 3, 2006 | 05:58 AM
Default Re: (kantfadedisazn)
well i hav to go bak to class but any help would be great, ima be bak at around 11am so thanks for the help
Old Feb 3, 2006 | 02:11 PM
Haha, at school huh, 11am your next study hall? Gotta give it up to the kids who are at school learning.....about honda's on HT.
I'm assuming by the "check engine light causing it" you mean the ECU, IDK if that could be it or not.
A more vivid description may help, and if you can get video/audio by any chance later, that may help.</TD></TR></TABLE>
yeah i think it might be the ecu, i can get a 15 second clip maybe of what is going on but that wont be till my friend lends me his camera
Old Feb 3, 2006 | 03:37 PM
any body else know any solutions?
Old Feb 3, 2006 | 04:33 PM
man this sucks
Old Feb 3, 2006 | 05:12 PM
C1CRX's Avatar
Traffic signal tech
i had a problem of my car bogging instead of accelarating in the morning after it had been sitting for a while and it ended up bieng my ECT sensor or my ignitor i cant remember LOL
Old Feb 3, 2006 | 05:22 PM
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">i had a problem of my car bogging instead of accelarating in the morning after it had been sitting for a while and it ended up bieng my ECT sensor or my ignitor i cant remember LOL</TD></TR></TABLE>
ohh but will that cause a check engine light to go on
Old Feb 3, 2006 | 08:36 PM
boostinaintez's Avatar
check your codes man then come back on here and discuss it with us.
Old Feb 4, 2006 | 06:36 AM
I thought he said it wasnt throwin codes, but after re-reading, I see he said nothin about it.
So yeah, get your codes and comeback. If you don't know what your codes are, just search</TD></TR></TABLE>
ok ima doing that today, ill let u guys know what the code is, hopefully its not bad
Old Feb 4, 2006 | 07:02 AM
ok i got the codes, it blinked 6 times, stopped, then blinked 9 times, stopped then blinked 10 times so ima guessing codes #6,#9,#10, i searched and #6 is coolant temp sensor, but i replaced that, and code #10 is air intake temp, and #9 i hav no dam clue, are those major problems, i know that #6 is but i put a new temp sensor, so i dunno if u guys know please help
Old Feb 4, 2006 | 07:45 AM
ok here is the update, code #9 CYP - cylinder sensor, that what the pm6 ecu is thrwoing, i had my buddie listen over the phone when i started the car, it stutters when it starts up then it starts, my buddie said that the timing is off by a tooth, so i dont know what to do could that be the problem why the car sputters when turning it on. please help
Old Feb 4, 2006 | 10:16 AM
help
PetersonJ39
Apr 2, 2011 05:59 PM
bub113
Dec 19, 2008 09:27 AM
ef8-dc2619
Jan 31, 2007 04:29 PM
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
shiithook
13
Apr 30, 2002 06:43 PM
