Is it possible to adjust timing belt tension w/ out removing lower cover??
Old Feb 3, 2006 | 05:29 AM
trecool44's Avatar
Default Is it possible to adjust timing belt tension w/ out removing lower cover??
Hello, I just replaced my timing belt two weeks ago. I have driven the car once since then. I pulled off my valve cover yesterday and my timing belt is loose. Is it possible to access the tensioner bolt with out removing the lower timing cover. I would remove the valve cover and the upper timing cover. I hope there it is possible beacause if not i would have to remore the ps belt, alt belt, and crank pulley to get the lower cover off. Thanks alot in advance.
Old Feb 3, 2006 | 05:47 AM
tpr's Avatar
tpr
Default Re: Is it possible to adjust timing belt tension w/ out removing lower cover?? (trecool44)
Yes, there is a plastic plug that covers the head of the bolt. Just look you will see it. The issue is having a socket/ratchet that can get on it and still fit between the front of the motor and inner the fender.
bdmlilburn
Jul 24, 2011 07:54 AM
732xghost
Sep 9, 2007 10:02 AM
noble4ws
Nov 11, 2003 05:27 AM
MidoriEK4
Mar 6, 2003 03:57 PM
