crx suspension swapping???
Old Feb 2, 2006 | 11:06 PM
neve12f0ll0w's Avatar
Default crx suspension swapping???
i wanted to know if anyone can tell me which suspension i can swap into my crx. i was looking for rear disc conversion and bigger front caliper and rotors. i wanted to stick with factory parts so can anyone tell me in different model acura's or honda will work? ex: upper a-arm, steering knuckles, etc... thank you in advance..
Old Feb 2, 2006 | 11:14 PM
VtecSyndrome's Avatar
Default Re: crx suspension swapping??? (neve12f0ll0w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neve12f0ll0w &raquo;</TD></TR><TR><TD CLASS="quote">i wanted to know if anyone can tell me which suspension i can swap into my crx. i was looking for rear disc conversion and bigger front caliper and rotors. i wanted to stick with factory parts so can anyone tell me in different model acura's or honda will work? ex: upper a-arm, steering knuckles, etc... thank you in advance..</TD></TR></TABLE>
USE THE SEARCH! but until then your best doner car is a 90-93 Integra for front and rear brakes. If you really want bad *** brakes talk to "https://honda-tech.com/zero...46017" because he has ITR front calipers and rotors, you just need 88-91 EX front spindles and milled down caliper brackets to pull it off, you also need to redrill the rotors to 4 bolt instead of 5. do a search and you will see this topic!
Old Feb 2, 2006 | 11:31 PM
Tyson's Avatar
sounds like you want a bigger brake setup, not "suspension".
https://honda-tech.com/zero...age=1
Old Feb 2, 2006 | 11:50 PM
onepoint6i's Avatar
Default Re: crx suspension swapping??? (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
USE THE SEARCH! </TD></TR></TABLE>
bahaa..
Old Feb 2, 2006 | 11:56 PM
STREETWERKZ's Avatar
Default Re: crx suspension swapping??? (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">bahaa..</TD></TR></TABLE>
/\ and you called me a post *****.
:rolls eyes:
Old Feb 3, 2006 | 06:56 AM
Default Re: crx suspension swapping??? (STREETWERKZ)
thanks for the help guys.
Old Feb 3, 2006 | 07:08 AM
onepoint6i's Avatar
:rolls eyes:
what? it was funny fool
redrusch
Jul 28, 2007 08:00 PM
gtturborex
Oct 1, 2005 06:13 PM
mechengine
Jun 5, 2004 08:16 AM
neoboi
Feb 22, 2004 10:17 AM
